engine spins effortlessy
Old Oct 13, 2009 | 09:25 PM
  #41
xcmountain80's Avatar
Wish my $300 went that far.
A
Old Oct 13, 2009 | 09:33 PM
  #42
camo31_10.50's Avatar
uhm..i looked..and where the heck did the $300 figure come from?????
Old Oct 13, 2009 | 09:42 PM
  #43
MUNJUE's Avatar
Old Oct 13, 2009 | 09:43 PM
  #44
raydouble's Avatar
Well, I wasn't expecting that............lol
Looks like your timing belt was ready to go also.
Old Oct 13, 2009 | 09:44 PM
  #45
raydouble's Avatar
Originally Posted by MUNJUE
so if you cam marks line up, then I dont think you will have bent valves,
do you have a oil can, 2-3 squirts or drip (5-10) mills, in each plug hole, with the plugs still removed turn over motor on starter motor, to remove excess oil, refit CLEAN OR NEW plug
try to start with throttle open it will smoke for a few minutes due to the oil in the cylinders.
Old Oct 13, 2009 | 09:48 PM
  #46
hellfire's Avatar
Umm right here...
Originally Posted by vr4boy
anyway,i'm pulling the heads and checking the condition of the block,pistons,oil passages and cylinder bores if they are salvageable i'll be slapping in some rebuilt heads...if not,thinking of going JDM and swap out the whole motor.....
i guess i'm still ahead as she sold me this 2000 ltd for $300.
Old Oct 13, 2009 | 09:51 PM
  #47
vr4boy's Avatar
MUNJU
i did the oil in the cylinder test prior to the valve covers being removed and still got zero compression it was the final straw b4 openning her up...
thanks for the suggestion
and oh thats an 8k mile belt-it actually still looks good up close but,def not using it on my "possibly" next motor
Old Oct 13, 2009 | 10:01 PM
  #48
raydouble's Avatar
That pic does it no justice then......looks like hell.
Old Oct 14, 2009 | 12:28 AM
  #49
98runner210's Avatar
Castrol GTX every 3K miles:
Old Oct 14, 2009 | 01:42 AM
  #50
vr4boy's Avatar
that's what i call big time difference night and day....literally
Old Oct 14, 2009 | 04:36 AM
  #51
Team420's Avatar
motor/head
top of lifter bucket not contacting cam lobe(stuck in open pos'n due to gunk)
That is just nasty!! Never seen one quite that bad bafore.
Old Oct 14, 2009 | 05:34 AM
  #52
Built2Grind's Avatar
just whatever you do NEVER USE PENZOIL in the yellow bottle, your motor will look like that but it will be crusty, not gummy
Old Oct 14, 2009 | 06:20 AM
  #53
DeathCougar's Avatar
I have seen it that bad, and worse.
Camry engines are notorious for doing this. But really, all it stems from is not changing the oil. People blamed toyota and there was a huge recall, but it was merely because people were too lazy to go to quicky lube and change the stupid oil. At least the truck was only $300! Now you can afford a new engine
oh, and who was right? This guy
Old Oct 14, 2009 | 06:21 AM
  #54
mt_goat's Avatar
Wow, that's bad sludge.
More on sludge here: http://www.yotarepair.com/Sludge_Zone.html
Old Oct 14, 2009 | 07:42 AM
  #55
Thats thinking with your dipstick Jimmeh!
Old Oct 14, 2009 | 08:51 AM
  #56
Compressed's Avatar
This thread has me really wanting to pop a valve cover and see what my runner is like.
I bought mine with 110,000 miles and I think it was female owned in it's prior life.
I've done a AutoRX clean and rinse phase and am doing another clean phase now and the motor has gotten smoother but not drastically so. It's hard to see much looking through the oil fill hole that's for sure.
To the OP. You are still way ahead, get ahead a decent replacement motor and move forward.
Old Oct 14, 2009 | 09:09 AM
  #57
TOYOTA 1's Avatar
lol bore wash.. leaky injector hehe..
ok im done lol.
though i will admit that sludge would have not crossed my mind.
dc you didnt say anything about sludge did you?
Old Oct 14, 2009 | 10:48 AM
  #58
No, but I said pop the valve cover, i bet that cam isn't spinning.
One pop of the valve cover revealed the problem
Old Oct 14, 2009 | 11:56 AM
  #59
TOYOTA 1's Avatar
gotcha
Old Oct 14, 2009 | 02:12 PM
  #60
vr4boy's Avatar
yup sludge galor
