Engine removal questions
Old May 8, 2004 | 07:05 PM
patterson's Avatar
Im removing my 3.0 v6 from my 90 toyota 4x4 now ive heard both ways and i was wondering if you can just unbolt the tranny while its in the truck so you can just pull the engine out?
Old May 8, 2004 | 07:24 PM
My99's Avatar
I agree, i'll be doing this soon too. I don't necessarily need to pull the tranny, just the motor. Sorry to threadjack, if in fact I am.
Old May 8, 2004 | 07:36 PM
bike4miles's Avatar
Leave the trany. There are a few bolts by the firewall that are hard to get at but it is easyer to pull that way. It only has to move forward about 6 inches that way.
Old May 9, 2004 | 10:40 PM
muskie's Avatar
I pulled just the engine. was a bit of a pain to get the top three bolts for the tranny but once I got the crossover off, it was smooth sailing. I found I could just fit a wrench in fron the top to break the bolt loose and then used a flex socket with a big extension to get them the rest of the way.
Old May 10, 2004 | 12:42 AM
jimbo74's Avatar
i have a 22r, and just did an engine swap.... on mine, you just unbolt the engine from the bellhousing, and it comes out and leaves the tranny...... just make sure you have something under the tranny to catch it....
Old May 10, 2004 | 03:38 AM
934rnr's Avatar
I just put my engine back in. I would unbolt it from the xsmn.
You can use a small jack and a block of wood to support the front of the transmission bellhousing.
Old May 10, 2004 | 03:59 AM
FireMan's Avatar
I just got done pulling and reinstalling my engine as well. I would leave the tranny in the rig. Detach the lower 3-5 bolts from the bellhousing to the engine. You will then be able to remove the lower plate between the engine and tranny. If you have an auto, be sure to disconnet the 6 bolts that hold the flexplate to the torque converter before pulling the engine. Then place a support under the tranny, pull the other bolts and you are good.
bigjstang
Jun 2, 2025 03:56 PM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
ItsJustD
Jul 7, 2015 07:49 AM
