when do i get new timing belt?
Old May 9, 2004 | 09:18 AM
Amir904's Avatar
i have 94k miles on my 98, when should i replace my timing belt? i have mostly highway miles, dono if that matters, and how much should it be?
Old May 9, 2004 | 09:21 AM
Designsbyme's Avatar
Not sure when you're supposed to get one. But I know they're about $50.00
Cost to install is about $300.00. It's $50.00 if you do it yourself.
Old May 9, 2004 | 10:30 AM
alltheway's Avatar
I have heard from people at Toyota that it should be done every 60,000 miles. However from my local Toyota shop they say to do it at 80-90,000 miles.
Old May 9, 2004 | 10:36 AM
Scofco's Avatar
I had mine changed a couple weeks ago.
The dealer recommended every 90,000km's. Mine was done at 190,000km's
Tough belts.
Old May 9, 2004 | 11:22 AM
Grim13's Avatar
60,000 is way too early. It shoul last you until about 110 until it blows up. I got mine done @ 90k. You should get your water pump replaced too while you're at it.
Old May 9, 2004 | 01:31 PM
KevyWevy's Avatar
yup, like Grim said, 90k miles. it should last till around 100k. and its a good idea to get the water pump replaced at the same time while you have it all taken apart. i actually went in for my leaking water pump and got a new timing belt as well.
Old May 9, 2004 | 03:12 PM
midiwall's Avatar
I've always heard 90k, though I'm at 126k and am looking to do it "soon".
I've ordered the belt and water pump (thanks TOR!) and the parts should be here this week. I'll set up a time with a local buddy for his garage space and expertise and make it happen.
Old May 9, 2004 | 03:59 PM
MTL_4runner's Avatar
I've seen em break anywhere from 90k all the way to over 230k....
....change it no later than 90k or you are playing russian roulette.
It is very dangerous for it to break and lose all power on the highway!
Old May 9, 2004 | 08:16 PM
BASSMAN's Avatar
Talking
Had mine done last week at 84,000 miles. I bought my parts online: thermostat/gasket, water pump, t-belt, and all 3 drive belts. My local mechanic did it all for $300 labor. I am very happy with the work that he did - it really seems to run a lot smother + that annoying squeaking noise is finally gone!!!!!!
Up next on my plate installation of my new long's lpd 4452 tranny cooler and magnafine inline filter. I will also have the rear transfer seal replaced (its leaking )
Good luck with the belt - it's definetly time to get' r' dun' !!!
Old May 10, 2004 | 05:07 AM
4RunnerFever's Avatar
90,000 is what the owners manual says. I did mine at 68k along with a host of other maintenance items just to be sure since I had to agree to drive this thing for 10+ years in order for the wife to agree to it
Eggslinger
Jun 8, 2019 03:32 PM
thefishguy77
Jul 30, 2015 10:59 AM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
