Engine oil "low" after 2200 miles service
Old Jan 16, 2004 | 06:29 AM
KING's Avatar
The dipstick read a tad bit below the "low" mark.
This is 2200 after I did the oil.
Is this bad?
Old Jan 16, 2004 | 07:44 AM
Bennito's Avatar
I'll bite (I sure hope this isnt a troll)
Being low on oil after 2200 miles wouldn't seem to be good. Have you been checking regularly since the last oil change? Perhaps there is a simple answer like filling up a quart short. Is there a substantial amount of oil on your block? Is your exhaust notoriously grey/blue?
Old Jan 16, 2004 | 07:48 AM
rimpainter.com's Avatar
Make sure you are on a completely flat surface and the engine is cold too. If the answer is still yes, then yeah its bad.
You should figure 0 - 1 qt of oil burning between changes depending on the vehicles overall mileage and conditiion. It also depends on what weight of oil you are using.
My 96 burns about .5 qt of 5 - 30WT synthetic every 5K miles.
Old Jan 16, 2004 | 08:01 AM
KING's Avatar
I'll check tomorrow when the engine is cold on a flat surface.
I checked the oil at about 1500 and everything was good.
I am running VALVONINE 10W-30.
When I replace my oil, I put in 5.5 QTs.
I'll have to take a close look at my exhaust, however, I do have a bad exhaust smell. Very strong.
This is not sounding good
Old Jan 16, 2004 | 08:05 AM
My99's Avatar
It's probably not cold in phoenix, but watch your tailpipe when you start up the truck and see how much blue smoke comes out. I assume you're not loosing any on the ground. If you're losing a lot of oil on startup (blue smoke) then you have worn rings i'd say. Otherwise, might just need a valve job done and put new valve seals on it. i wouldn't be to worried, it's not the kind of problem that just leaves you stranded one day, it just slowly eeks power away.
Old Jan 16, 2004 | 10:13 AM
AgRunner06's Avatar
Post
I believe Toyota recommends warming it up and then letting it sit for 5 or 10 minutes before checking the oil. I don't think it really matters. I check my oil both ways.
BTW, I go through about 1 quart every 1K miles. But that's because I have leaks. :cry:
I wouldn't be too worried unless you are getting a noticeable cloud of blue/grey smoke coming out you exhaust.
Vehicles get old and leak a little. That's the way I look at it.
Old Jan 16, 2004 | 12:10 PM
Bennito's Avatar
Originally posted by AgRunner06
my oil both ways.
Oil leak quotes i've heard:
Its not leaking oil, its marking its territory
When it quits leaking, it means i'm low on oil.
Had a few more....friday afternoon must be sapping away my useless brain power.
Also, you may be able to see the oil burn (if its there) when taking off, in a hurry, at low rpms.
Old Jan 16, 2004 | 01:26 PM
KING's Avatar
stagger_lee
Mar 29, 2016 06:27 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Vargntucson
Jul 4, 2015 12:15 PM
Robinhood150
Aug 8, 2002 05:57 AM
