engine light code P0120
I have a 99' 4Runner with the 5VZ FE & just recently my check engine light came on but it would come on & off randomly. My buddy used his scanner & came up with this code: "P0120 throttle position sensor A circut". The next day I took it to my local Toyota mechanic & he told me to get some throttle body cleaner & an old toothbrush & clean the carbon deposits inside the throttle body because it may be dirty & it may fix the problem. Has anyone had this problem before & attempted to clean the inside of the throttle body? The reason why I'm asking is because I want to know if the carbon deposits affect the TPS sensor & if cleaning it cures the problem? I want to hear your inputs before I spend $130 for a new TPS sensor from Toyota!
dude, don't ever spend that much for a part like a TPS from Toyota...i had the same code and picked up a new TPS from autozone for $60, and it's fixed all my problems and comes with a nice warranty...save yourself the time of cleaning and just get a new one...trust me
Thanks for the advice Mike! Well my mechanic told me that he did it to a few other toyota cars & it seemed to work. But he also told me to just try it out first to see if the problem goes away before I start spending money. What is the make of your aftermarket TPS so I can go to my local parts store to see if they carry it because in up here in Canada we don't have an Autozone just NAPA. Because I'm afraid they might tell me that they don't carry it & it's only an OEM part!
Do have the part # by any chance?
edit: OEM Number: 89452- 35020; 89452- 35100
this was also listed on their website under the Duralast part number...just thought i'd post it
it was just the Duralast brand from Autozone, part # TPS482 as stated on their website and comes with a two year warranty...and it also looked exactly like the one that i pulled off the truck as far as markings, colors, and numbers/letters...and my bad on the price, as it was really only $49.99
Well thanks again Mike that saved me about $80 buying from the dealer!
Not wasting your time and just buying the sensor from autozone is the best way to go, but just thought i would throw out there i have had that code as well as having my IAC valve stick closed while driving. I removed my throttle body and cleaned every thing out with throttle body cleaner and have not had a problem since. That was last summer.
Just for fun I checked NAPA--they list two: an Echlin for $53 and a Delphi for about $70. So these are pretty easy to find. I use NAPA because they are two miles way, Autozone is about 15.
if ur throttle body is dirty, you should still clean it. It could lead to hesitation. seems a bit foolish to just throw parts at it rather than spend 10 minutes and a $4.00 bottle of cleaner to try and see if ti fixes it. If not, oh well you now have a clean throttle body if it does work then good!
Get the Toyota part number. A little time on the internet will cross reference will the OE part number with the Denso part number. Then order the Denso part from Ebay.
I cringe when I hear of Autozone or NAPA parts being installed on a Toyota engine.
My 99 kept randomly throwing that code. Eventually we swapped it with the TPS on my wife's 96. The 96 doesn't seem to care the slightest (never throws a code), and the 96's TPS works perfectly on the 99.
I just had the P0120 code and bought a TPS at Autozone. Cleared the code and it has not returned after a few hundred miles, so that was probably it.
It's not the most sophisticated part. An Autozone TPS seems about as risky as Delco wiper blades. JMO.
p.s. Thanks folks for the diagnostic help.
Tps p0120
First Welcome to Yota Tech !!
The people who told you to just get rid of the truck most likely wanted it themselves.
We will get this figured out.
One must remember when you get any code it is not just the sensor in question.
Was the old TPS even tested or just replaced??
Some real poor quality parts out there these days failed out of the box??
In your case it just be a corroded connection.
Are you able to do some mechanical work yourself or at the mercy of paying someone.
Be nice to know where you are help could be close at hand
Things to know mileage and drivetrain??
