Engine light came on: Manufacture Contrl. Transmition
Old Sep 5, 2005 | 05:44 PM
rytek's Avatar
My engine light came on so I went to autozone to see if I could figure out what it was. It was code p1700 Manufacture contrl. transmition. I was wondering if anyone else has had similar problems or had any idea of what it might be. I will take it into the shop later on this week but have to make a 200 (both ways) drive and wanted to make sure it was ok to go ahead and make the drive.
Old Sep 5, 2005 | 07:06 PM
rimpainter.com's Avatar
What vehicle?
Old Sep 5, 2005 | 07:33 PM
rytek's Avatar
opps, I have a 97 4runner limited 2wd
Old Sep 5, 2005 | 08:08 PM
trx125's Avatar
According to OBD2 codes that is TPS malfunction or short circuit(.TPS Circuit Malfunction For AT )to be exact. May have to replace the TPS! You can do it!!!!
Old Sep 6, 2005 | 05:52 AM
Test the TPS before you replace it. You will need a multi-meter and FSM to do it right. If you don't have the FSM, you can download what you need via PDF at the TIS website for $10 (per day fee). The TIS information is right out of the FSM. I have used it before.
Old Sep 8, 2005 | 01:50 AM
rytek's Avatar
The engine light seemed to have turned off by itself. It has done that from time to time. Is that odd?
Old Sep 8, 2005 | 05:18 AM
MTL_4runner's Avatar
When I look up code P1700 on Auterra I get "vehicle speed sensor 2 circuit".
I am not sure which wheel that is in relation to.
The code that is listed on the YT OBD II code page is for a Subaru.
That is certainly not a common code for sure.
snosurfer
3.4 Swaps
Aug 15, 2024 02:11 AM
smthwsn357
May 1, 2024 07:28 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
