Engine dies and will not start again...
Guys,
Was making a turn tonight at a stop light and my engine just cuts off. I try to start it again, but the starter just cranks and cranks; no turnover. What could this be? No check engine light, plenty of gas, etc. Idle speed seems to be normal.
I suspect something electrical because my two amps stopped coming on with the key. Everything else electrical works fine though. No fuses blown. My father disagrees. He thinks it's something fuel related.
Any ideas?
BTW- I just remembered that yesterday as I was sitting at a stop light, the RPMs dropped really really low (like sub-500), but came right back up. If this helps any...
Any ideas?
First, I would disconnect one of the spark plug wires and hold it close but not touching the distributer. If you can hear and/or see the spark then your electrical is good.
If that checks out I would crank on the truck for a little bit and then remove one of the spark plugs. If you are getting fuel the spark plug will be wet. If the plug is dry, I think your fuel pump probably went out.
Good Luck
Thanks for all the replies.
For the record, it turned out to be the 30A starter/ignition fuse. Somehow, one of the pulleys sliced the thick starter wire causing it to short out while I was driving. I ended up re-routing the wire to where this wouldn't happen again.
Team420
Jan 12, 2021 04:57 PM
91toybeater
Dec 27, 2015 07:46 PM
