Engine changeout 5vz-fe
Old Aug 3, 2006 | 07:09 AM
kwikrnu's Avatar
I checked compression and it was okay except for one cylinder was 140. It ran great except for the missing hesitation at WOT. So I went down to the salvage yard on tuesday and got another 5vz-fe for $850 (don't know if that is good or bad-came with harness and alt and coils etc.) on Tuesday and in my spare time will change it out.
The engine has 215K miles and rear oil seal was leaking and the timing belt probably hasn't been changed in a long time too. So, I figured might as well do an engine.
Pretty straight forward. Remove battery, various vacuum tubes, fuel hose, upper intake, existing wire harness, starter, exhaust, torque converter bolts, trans to engine housing bolts with long extension, a/c and power steering left in car, motor mounts and she looks ready to remove. Took about 3 hrs.
Hopefully can get it in in about 4-5. It is always easier to take stuff off.
Here is a cool pic of a rat I found cooking under the intake.
new engine
wire harness that came on engine-does anyone know what it fits?
Old Aug 3, 2006 | 07:22 AM
mastacox's Avatar
Egads that's digusting
Old Aug 3, 2006 | 07:38 AM
mt_goat's Avatar
That's an engine harness for a 5VZFE alright. I guess you want to know what year?
Old Aug 3, 2006 | 07:42 AM
kwikrnu's Avatar
It looks to be from a manual transmission because the harness on my automatic truck appears to have many more connectors for the transmission. I was also wondering if it was for a 2wd and what computer /pcm the pins would match up to. I figured it may be worth a few bucks on ebay which is ultimately why I wanted to know.
Old Aug 4, 2006 | 05:14 AM
kwikrnu's Avatar
Anyone know the difference in injectors on the 5vzfe engine?
The new engine came with brown injectors 23250-62040. The old engine had 23250-62030 green light blue injectors.
I just left the brown injectors in it.
BTW, everything works good and it is much smoother.
snosurfer
3.4 Swaps
Aug 15, 2024 02:11 AM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
