ect power switch
Old Sep 24, 2011 | 04:54 AM
Potomacduck's Avatar
I use it once in a while when merging onto the highway.
It allows the engine to rev right up to 5,000 rpm and that helps blow out the carbon from your valves.........much better than a can Seafoam will ever do.
Old Sep 24, 2011 | 09:18 AM
99 sas runner's Avatar
I took mine down the race track 4 times im sure its cleared of carbon
Old Sep 24, 2011 | 11:59 AM
ZUK's Avatar
ZUK
I've been playing with my ECT button lately and I have noticed it does 2 things. It raises the shift point as you know but it also seems to increase the fluid pressure to the clutches which firms up the shift points....less clutch wear I bet but gears are a little grabbier....a good thing actually.
If you are easy on the pedal then the shift points don't seem to be that much different than with the button off. I just leave it on all the time.
Old Sep 24, 2011 | 02:11 PM
BoostedRNR's Avatar
I could tell a big difference when I would use this on my turbo when it was an auto and then I bought my 00 and can't really tell much of a difference at all. Maybe a little firmer on the shifts but that's all I can tell.
Old Sep 24, 2011 | 02:33 PM
  #25
sdsurfer's Avatar
Originally Posted by 96743runner
or if you don't want to turn overdrive off.
like ! ! !
Old Sep 24, 2011 | 08:56 PM
  #26
mine is ALWAYS ON!!! ill be doin a-hundo on the freeway on 37s
Flying91
45
Apr 11, 2024 04:39 PM
okamikai
Apr 30, 2018 10:19 PM
montanatruck
Feb 26, 2017 07:07 AM
94yotaky
Jul 23, 2015 07:50 AM
Johntom240
7
Jul 13, 2015 12:18 AM
