ECT button manual trans
Old Apr 4, 2012 | 08:43 PM
thedanned's Avatar
Hi all
Trying to get back into the Toyota game after selling my 89. I found a 99 4R SR5 4x4 5vz manual. Nice truck but one weird thing: It has an ECT button on the dash above the HVAC controls. I pushed it and I didnt see any lights come on. Has this truck been swapped to a manual? The owner didnt have any info on it. Are there any telltale signs of a manual conversion? No CELs or anything.
Edit: clutch master looked fairly new and the fluid was crystal clear.
Thanks
Old Apr 4, 2012 | 09:24 PM
thedanned's Avatar
Wait a minute I found my answer - I forgot about the ID Label on the LF door. Ill take a look at it tomorrow and see what it says.
Old Apr 4, 2012 | 09:50 PM
justin_4runner's Avatar
u can also look at the bolts that hold the brackets and pedals in, does the lines that go to the slave look new? or ran my the manufacturer? if they did the 5 speed swap i dont see it being a bad thing, after all i did it to my rig.
Old Apr 5, 2012 | 06:58 PM
thedanned's Avatar
Well I bought it. Door tag says R150F so I dont know whats up with the ECT button. Ill post up in the newbie section to reintroduce myself but for now heres a couple of pics. First things first: remove the running boards! God I am so glad to be back in a Yota.
Old Apr 5, 2012 | 08:17 PM
not too bad of a looking rig, it might change the fuel and timing a little or then needed something to fill a open spot and thats what they came up with and it might not even be hooked up.
Old Apr 5, 2012 | 08:53 PM
toyota4x4907's Avatar
Dig into the dash to see if it is hooked up
Old Apr 5, 2012 | 09:24 PM
thedanned's Avatar
Thanks! Theres been some body work but it came with eight years of maintenance receipts so I was happy with that. Its got the rear e-locker too which pretty much sold it for me.
The ECT button is backlit so the harness is hooked up. Ill dive in this weekend and see where it leads.
Old Apr 5, 2012 | 10:11 PM
5spd + E-locker? Damn. Thats nice
Old Apr 6, 2012 | 03:30 AM
KZN185W's Avatar
could be the PO did the center bezel mod
Old Apr 6, 2012 | 05:09 AM
thedanned's Avatar
Hmm from what I read here
https://www.yotatech.com/forums/show...t=43660&page=2
That is to put a 99+ bezel in but mine is a 99. Am i missing something? That does look like my bezel.
Old Apr 6, 2012 | 09:55 AM
stockwell45's Avatar
Maybe your original bezel was broken somehow, so they swapped it out with another one?
Old Apr 6, 2012 | 09:56 AM
ALLDATAdiy INFO's Avatar
FormerVendor
Does your cruise control work?
Old Apr 6, 2012 | 10:08 AM
thedanned's Avatar
Nope. Cruise light comes on but it wont set.
Old Apr 6, 2012 | 10:14 AM
FormerVendor
I'd do a voltage check on the ECT terminal coming out of your cruise control ECU. ALLDATAdiy says that it should be between 8-14v.
Old Apr 6, 2012 | 10:18 AM
thedanned's Avatar
Ok. What are you driving at?
Old Apr 6, 2012 | 11:10 AM
swerks's Avatar
I thought ECT was only active for automatics ???
Old Apr 6, 2012 | 11:42 AM
PhdNPrerunners's Avatar
X2 On This
Old Apr 6, 2012 | 12:05 PM
Jomoka's Avatar
Or someone wanted another switch for something.
My wife's '96 has a few 4Runner switches in it that aren't original equipment. Running lights, auto-antenna turn off (for playing CD's), stuff like that. Random switches from the pick-n-pull look better and fir properly.
Oh and *high-five* to the OP for the 5-spd e-locker. I had to look for a long while to find mine. '99 Highlander 5-spd e-locker.
Yours looks like a Higlander package too, SR5 with body colored bumpers and a snort-hood. Good stuff.
Mine's green and has the no-running board flares.
Old Apr 8, 2012 | 09:30 PM
thedanned's Avatar
Thanks for all the insight everyone. I installed my stereo today and found that the button is definitely plugged in. The po must have changed the bezel or clock at some point. When I was putting it back together I plugged the harness into the back of the ETC button and noticed the clock and rear defrost werent working. I removed the harness from there and plugged it into the back of the clock and they came back.
Took the running boards off too.
Old Apr 8, 2012 | 09:33 PM
thedanned's Avatar
What do you mean by this?
westonian18
May 1, 2020 06:38 AM
this_guy
Jul 31, 2015 01:27 PM
keithporter83
Jul 24, 2015 07:37 AM
KBar
Jul 13, 2015 06:01 PM
Poncho0206
Jul 10, 2015 06:21 PM
