Ect
Old Aug 5, 2003 | 03:39 PM
Ect
I have to ask about the ECT again. I was told it stands for Electronically Controlled Transmission, and it need to be on (in the lighted position) during city driving when there are frequent start and stops. When on the highway it is to be in the off position (unlighted) so the transmission changes the gears normally. I was also told it is for highway driving for more power. Next problem, I have an HKS Turbo timer, it malfunctions a lot, sometimes if it is set for 30 seconds it runs for more than 3 minutes, and other thimes it just does not work.
I must also say, this is one of the best sites I've been too and I have shown it to all my Surf and 4 runner friends in Trinidad. keep it up!
Old Aug 5, 2003 | 05:21 PM
Paul H.'s Avatar
Since you have a diesel, lucky you, it may be different but for ours the ECT should only be engaged when you need extra power like in pulling objects, going up a steep hill, or jack rabbit starts otherwise keep it off. It will efffect gas milage and the engine will shift differently. Hope this helps.
Old Aug 6, 2003 | 06:47 AM
mtnfreak's Avatar
The ECT changes the points at which the computer tells the transmission to shift. ECT on delays the upshifts and allows the engine to build more RPM's - for mine it seems to delay the downshifts too. I don't like the shifting in either position so I tend to shift manually more that I probably should.
Old Aug 7, 2003 | 03:00 PM
Thanks
Thanks for the replies. I think it should work the same for diesel and gas alike. When it is on, the gears change a lot faster, I'll use it with loads only.
Old Aug 7, 2003 | 03:01 PM
Thanks
PaulH, your rig looks a LOT like mine!
Old Aug 7, 2003 | 03:51 PM
AznSky's Avatar
Are you sure you have your turbo timer hooked up correctly? Is it the type that actually reads engine rpms and calculates the time, or does it just calculate the time it should be left on by the amount of time the engine is running?
Old Aug 8, 2003 | 02:29 PM
Timer
I can't say if it is the type that reads the rpms or the type that is an actual timer. I says Random Access Control on it. It is a used unit I bought so I don't know any details on it. The mechanic took it to an electrican to install so I don't know about the connection either. If someone has the specs on this model i would appreciate it, thanks
Old Aug 8, 2003 | 02:52 PM
AznSky's Avatar
Does yours look like this?
Or this?
You can also contact www.hksusa.com if you are having problems with the timer itself.
Old Aug 9, 2003 | 10:12 AM
nope
nope, it is a black box with a green digital display, just wide enough for the H, 1, 3, or 5 to be displayed.
Longbed 90
Mar 11, 2019 12:38 PM
camel_65@hotmail.com
Oct 3, 2018 06:11 AM
Longbed 90
Oct 19, 2015 11:05 AM
Boomer8404
Sep 24, 2015 01:12 PM
Boomer8404
Sep 20, 2015 06:15 PM
