easy differential oil change
Old Aug 7, 2003 | 09:32 AM
rimpainter.com's Avatar
Originally posted by oly884
Ok, I'm thinking of replacing the fluid in my transmisson and transfer case. I've got the 5-spd with ADD. Now, Corey, it says that you put in 1.2 qts of fluid in the transfer case for manual trans with ADD, right? Does anyone know how much goes in the transmisson? Also, what weight and should I use dino or synthetic for the transfer case and transmission? Thanks
If its anything like mine, than you put about 2.7 qts of 75 - 90W (or until it drips from the fill plug) in the trans.
Amsoil synthetic all the way!
Old Aug 7, 2003 | 09:38 AM
oly884's Avatar
Guest
Alright, so, 5 qts should take care of it. 1.2 and 2.7 is 3.9 so, having an extra quart should do it then.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
Ladythump
22
Nov 9, 2015 08:53 AM
horunner1x
Jul 10, 2015 06:33 AM
AaronM
Jul 8, 2015 07:15 PM
