driving lights not working
Old Aug 23, 2004 | 09:54 PM
patterson's Avatar
my front driving lights work and my brake lights work but my rear driving lights dont work?
is there a fuse somewhere or some easy fix
Old Aug 23, 2004 | 10:01 PM
patterson's Avatar
also my dash lights dont work either
wonder if they work together
Old Aug 23, 2004 | 10:09 PM
cabbage's Avatar
Yup, thats a blown fuse... What Generation 4runner or truck do you have?
Old Aug 24, 2004 | 10:18 PM
patterson's Avatar
i have a 90 truck deluxe
Old Aug 25, 2004 | 10:14 AM
patterson's Avatar
checked all my fuses and found the left hand headlight blown i replaced it and i still dont have dash or driving
Old Aug 25, 2004 | 11:15 AM
Tyson94SR5's Avatar
Im not positive, ( Havent looked yet), but there might be more fuses behind the glovebox if you havent looked there yet. Driver side panel, under hood, and behind glove box I believe. Still sounds like a fuse with the dash and driving lights out. If you have any aux. lights wired into your stock lights check to make sure that nothing came loose there. Another Idea would be to get out the voltmeter and check to see if you are getting power to these lights. If no power, fuse still an option. If has power then, light itself is probably bad.
Old Aug 25, 2004 | 11:32 AM
blink's Avatar
In addition to tysons suggestion. I would re-check the fuse to the left headlight again. You might have a short somewhere in the system that is blowing the fuses as fas as you are putting them in.
Old Aug 25, 2004 | 05:26 PM
cabbage's Avatar
Like the guys said check the fuses in the cab, especially the fuse box behind the kick panel on the drivers side
Bigger second pic
Old Aug 25, 2004 | 09:53 PM
patterson's Avatar
all fuses are go
the tailights fuse is good i check all inside the cab unless theres a box behind the glove box
Old Aug 25, 2004 | 09:56 PM
blink's Avatar
I guess its time to bust out the voltimeter and start checking to see if your even getting power. Where or how your suppose to accoplish this you ask? Im hopping one of our electrical experts will drop in. soyy I cant help more
Old Aug 26, 2004 | 05:00 AM
cabbage's Avatar
Well... at least we know the rear driving lights, parking lights, and dash work all together...(when mine went out I swear I checked the fuses, a few times too! A Day or two later I went back and found fuse #4 blown... )
You go through deep water lately? Done any work on your truck?
Old Aug 26, 2004 | 09:32 PM
patterson's Avatar
i have went through alot of deep water but im not even sure when they stopped working or if they have since i got the truck first time ive driven it in the dark
Old Aug 29, 2004 | 10:30 PM
patterson's Avatar
i found the problem while checking under dash fuses i saw there was something missing and it looked likea plug in and in letters above it said wow tail light relay, checked my paretsn toyota and there it was so i got one put it in and its works great
thanks for all the help guys nice to have a second opinion
gog1968
Jun 22, 2015 05:55 AM
ItsAtoyotaLIFE
Jun 21, 2015 11:45 AM
infinityisfive
Jun 16, 2015 06:51 PM
LSUMatt1514
Jun 26, 2002 05:03 AM
