Drivers windshield wiper won't work...
Old Feb 17, 2010 | 07:48 PM
Mason Dixon's Avatar
Had some ice the other day and thought it had melted enough to use the wipers to wipe off the slushy ice....turns out the drivers side one was still frozen in the ice. Turn them on now and only the passenger one works, not really sure where to start diagnosing the problem here, any ideas?
Old Feb 18, 2010 | 01:02 AM
rocket's Avatar
Does it try to move or is it still frozen?
Pull the "wiper fuse" for 30 secs and test. If nothing, remove the cowl and inspect/clean the mechanism thoroughly and re-test.
Old Feb 18, 2010 | 06:07 AM
Beto's Avatar
Hopefully a picture is worth a thousand words. I think the center linkage has come unstuck on you. Good luck, that can be a bear of a problem when it's cold out. I remember the cuts and bruises from trying to reattach my wiper motor through it's mounting hole (without taking the cowl off).
A sure sign of this is if the driver's side wiper can be moved by hand with the motor off. But then again, it might be all jammed up in there and not move by hand.
There is no way this is an electrical problem if the passenger side works and the driver's doesn't.
Old Feb 20, 2010 | 06:02 AM
Thanks for the help, turns out the nut was just needed to be tightening down.
okamikai
Apr 30, 2018 10:19 PM
mussy01
Dec 13, 2016 08:20 PM
94yotaky
Jul 23, 2015 07:50 AM
msane99
Jul 17, 2015 10:13 AM
coryc85
Jul 6, 2015 04:07 AM
