Driver's side window stuck down
Old May 15, 2022 | 12:42 PM
ddwyer's Avatar
The driver's side window on my '03 extracab suddenly stuck down today. There was no warning of sluggish "ups" in the past, nor did I hear any strange noises the last time it went down. The passenger side works fine.
I pulled the switch assembly up from the door handle and diagnosed the signals at the switch connector. Every signal at the door side connector shows the right voltage level for the desired window state (pass-up, pass-down, driver-up, driver-down); 12V when switched to desired position, 0V otherwise.
I pulled the door panel and check the continuity to each of the motor wires from the connector. They are both good.
I don't hear any driver's side motor noise when switched up or down.
Update:
After reading about slamming the door to fix it, I hit the door panel with a wooden mallet where the motor mounts to the regulator. It now works.
Is my problem more likely a bad motor or a sticky regulator? I have the door panel off, so now is the time to fix whatever is wrong.
Old May 16, 2022 | 05:55 AM
fierohink's Avatar
I’d say a bad motor. If it was a sticking regulator, you would hear the motor energize and bog down. Since you didn’t mention that, I’m assuming the motor isn’t powering up at all. Plus I would think you would’ve had a gradual slowdown and binding if it was the regulator versus an abrupt failure if it was an electrical fault.
Highlander Giant
Oct 30, 2016 02:35 PM
whambamthankyoumaam
Aug 19, 2014 07:16 PM
DRCOFFEE
Apr 30, 2013 09:10 AM
AndyL
Mar 22, 2010 08:07 AM
Jangles13
Nov 25, 2008 06:53 AM
