Does this not look good? (Coil-spring)
Old Mar 24, 2006 | 01:24 PM
BajaRunner's Avatar
I was looking at it today, and I thought that the coils shouldn't be touching...
These are stock Tacoma springs. Maybe I should go and get some OME's or something... Hmmm.. Just looks weird in there.
Old Mar 24, 2006 | 01:45 PM
bamachem's Avatar
ummm... i think i'd be more worried about the horny beavers under my rig doing the nasty...
Old Mar 24, 2006 | 01:51 PM
BajaRunner's Avatar
What?!!
Oh... those beavers.
Well, I don't know what to do about them....
So the coils look okay though?
Old Mar 24, 2006 | 02:00 PM
Tacoclimber's Avatar
I just remembered a Primus song I heard once..... :pat:
Old Mar 24, 2006 | 02:05 PM
BajaRunner's Avatar
I didn't know they wrote songs about BrokeBack coil springs!
oh maybe its the brokeback beavers.
Old Mar 24, 2006 | 02:09 PM
The song I'm thinking of had something to do with Wynona......
I'm guessing those are Taco TRD springs?
Old Mar 24, 2006 | 02:12 PM
Localmotion's Avatar
LMAO!!! random!
Old Mar 24, 2006 | 02:30 PM
FilthyRich's Avatar
"floating, horny, humping beavers"
Good stuff
Old Mar 24, 2006 | 03:11 PM
WATRD's Avatar
What you are seeing is called "coil bind" and it means that your suspension components are not properly matched. It most commonly happens when you attempt to lift a rig with progressive coils, but it can happen with single rate coils as well.
It IS NOT normal and means that not only are you not getting the full amount of lift you should be, you are riding around with only part of the performance you should be getting out of your coils.
If those are progressive rate springs, the fix is to swap them with single rate. If they are single rate, then you need to swap them with springs that are a better match for your suspension.
It won't really hurt anything, but it looks bad and you don't get the full benefit of your suspension.
I can't help with the beaver infestation. Try calling Winona, I hear she has a big brown one...
Old Mar 24, 2006 | 10:15 PM
BajaRunner's Avatar
Hey WATRD, thanks for the input.
These are stock Tacoma 4x4 springs. I am assuming they are single rate. I wanted to least amount of lift possible with my Trailmaster kit, so I just used the stock springs. I've now learned that Tacomas use different coil springs, and that could be causing the problem...Too much weight/lift/strain on the coils!!
So Im thinking about getting some OME's or maybe just saving up for some coilovers. That would be sweet.
I do have some weird noises when going over quick bumpy areas... I think the coils tend to give a weird vibrating noise from that.
Thanks for the help guys..
And, I really have no clue where those beavers came from, sorrry...
Old Mar 24, 2006 | 10:47 PM
1985 4Runner's Avatar
coleypull15
Nov 3, 2015 07:41 AM
Michael oaks
Jul 27, 2015 11:47 AM
PlayAwhile
Jul 20, 2015 11:36 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
Jnkml
Jul 6, 2015 01:20 PM
