does my truck have a low fuel light
Old Feb 8, 2004 | 08:08 PM
Brendan's Avatar
it's an entry level 4x4 (non-sr5) 92 4 cylinder reg cab (see below). when i shine a flashlight on the fuel gauge, i can definitely see where the light would be if it existed. i've never ran out of gas, but i've had it very close a few times. I wouldn't think that it's burnt out because how often would it be used? very little i'm sure. anyone know the facts with this sort of thing? thanks.
Old Feb 8, 2004 | 08:10 PM
Tacoma Dude's Avatar
I think a low fuel indicator light is a standard feature...
Old Feb 8, 2004 | 08:13 PM
Adam F's Avatar
Whatduya say there, sizzlechest?
(sorry for the jerky boys reference, had to)
I thought my light wasnt working untill it ran down WAAAAY below E and finally the light came on. How far have you ran it down? Past E?
Old Feb 8, 2004 | 08:21 PM
Churnd's Avatar
I don't think the light comes on unless your tank is bone dry. I looked at how much my tank held once right before a fill-up, and my fill-up was pretty close to that many gallons, so I figured the light didn't work. I'll have to get a jerry can and find out one day.
Old Feb 8, 2004 | 08:28 PM
Brendan's Avatar
i guess that's the only way to find out for sure besides ripping the dash apart. running the tank dry isn't healthy though, is it?
Old Feb 8, 2004 | 09:13 PM
Fink's Avatar
Mine has one, its just to the left of the fuel gauge...its hard to see sometimes, its amber colored.
Not sure if that helps...
Fink
Old Feb 8, 2004 | 09:21 PM
tenfourtyeight's Avatar
I've been wondering the same thing about my '91.
I don't want to run it down cause it's a 22RE, and the gunk in the bottom of the tank can mess up the EFI. If I had a 22R, I'd do it.
Old Feb 8, 2004 | 11:25 PM
Mossback74's Avatar
My brother claims the same thing on his 4cyl 99 Taco. Mine comes on when I still have 4 gal left
Old Feb 9, 2004 | 05:25 AM
PirateFins's Avatar
I've never seen the light come on in mine and I have run out of gas trying to get to the closest gas station. I'm not sure if every model has it hooked up?
Old Feb 9, 2004 | 07:09 AM
steelhead's Avatar
My 99 taco had what appeared to be a light but no light ever came on when I was on or near E. It was a entry level standard cab 4x4. After doing some checking into it here is what I found out.
Not every Toyota has a working gas light. It is there simply because the dash gauges are all the same whether or not you have the working light. So if you have an entry level Toyota you will not have a working log gas indicator light.
Old Feb 9, 2004 | 07:52 AM
toy283's Avatar
Some entry-level trucks don't have one, but it also depends somewhat on the year. My trucks don't but my '84 Camry (also an entry-level) did.
Old Feb 9, 2004 | 08:08 AM
Would there be any difference between standard and extra cab? Mine is definitely entry-level; 5spd, 4cyl, no AC, no clock- but it is extra cab. Does that have any significance?
Old Feb 9, 2004 | 08:26 AM
toy283's Avatar
May not. My XCab doesn't have one, but it is seven years older too.
Old Feb 9, 2004 | 09:10 AM
PirateFins's Avatar
No my 92 doesn't have one and I'm x-cab AC, 5cyl. So there is no difinitive factor.
Old Feb 9, 2004 | 12:58 PM
steelhead's Avatar
OK when did Toyota make a 5cyl???:pat:
Old Feb 9, 2004 | 01:15 PM
Brendan's Avatar
it says right in his post he's got a 92, duh!
Old Feb 9, 2004 | 03:04 PM
4Paws's Avatar
Mine comes on as the engine sputters to a stop.
Worthless as t _ _ _ on a bull!
Old Feb 9, 2004 | 04:25 PM
toy283's Avatar
He swapped in an Acura engine
Old Feb 9, 2004 | 04:28 PM
Well, since the spot for the light is already there, would it be possible to hook everything up so you have one?
Old Feb 9, 2004 | 06:13 PM
trd90toyota's Avatar
I have had an 90 pick-up it was a delux (entry level) and it didn't have a light, My 4runner has one. and it's a 90. I think it has to do with if you have a tach, The pick up didn't have one the runner has. Hope this help any...
