does front wheel alignment is required after shocks replacements ?
Old Jan 28, 2005 | 02:18 PM
fs8459's Avatar
Guest
Hi, I just replaced my stock shocks with the Tokico TrekMaster shocks on my 4Runner 3.4L V6 about 2 days ago. I am using the stock springs, only the shocks are replaced with the Tokico TrekMaster shocks. I am wondering if I need to perform a front wheel alignment or it is not required ? Let me know, thank you
Old Jan 28, 2005 | 02:23 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
I'm no expert but I don't believe you need an alignment after replacing front shocks on a 4Runner.
MTL_4runner's Avatar
After springs yes, after shocks no.
Old Jan 28, 2005 | 02:39 PM
Cebby's Avatar
Ditto
Old Jan 28, 2005 | 02:47 PM
95ToyotaPU007's Avatar
same here. after springs yes. shocks, if you need to get rid of some cash.
Old Mar 16, 2005 | 10:16 PM
Swede's Avatar
"fs8459", I'm considering the same shocks for my rig also. How do you like/dislike the ride of the Tokico's once you've installed them? How are they compared to the stock ones?
Old Mar 17, 2005 | 02:26 AM
shazaam's Avatar
explain this to me .. in order to do the front shocks you have to pull the front spring out. Then when you put it back in, it would need to be alligned, right? and if no, then why not?
Old Mar 17, 2005 | 03:30 AM
bamachem's Avatar
No, you don't. Replacing the shocks requires removal and rebuild of the coilpack. Unless you put a spacer in there or some other type of lift, then when the coilpack goes back in, it will rest at the same exact height as before, and therefore won't change the geometry of the front suspension, only the ride characteristics.
Old Mar 17, 2005 | 03:46 AM
shazaam's Avatar
ok, thanks
Mr.Black
Jun 21, 2015 10:17 AM
AustinTaco
Jun 21, 2015 09:54 AM
TheManOutside
Jun 18, 2015 03:32 PM
infinityisfive
Jun 16, 2015 06:51 PM
Hermes
7
Jul 8, 2002 03:45 PM
