Does anybody know to install glow pedals????
Old Sep 14, 2002 | 09:35 PM
sleepy1405's Avatar
Okay so I just got my pedals in a little while ago and they are supposed to glow blue after I hook them up to a 12v source and ground it too, but I have a question, where do I hook it up to without shorting out my battery or messing anything else up????? It looks really easy on the box I just don't know which one is the 12v source need some help please.
Old Sep 15, 2002 | 01:53 PM
butnut's Avatar
Hey Sleepy. Indi pedals? May as well since you're waiting on the gauges...I'm sure you want those pedals to glow only with the lights on, so you'll need to tap into a light source. The one I used for my lighting is the park light wire. Guys here have said the ashtray light is an close/easy tap. Maybe that one is good. The best ground I have found is the metal clip/screw that hold on the driver side kick panel. Remove the panel and you'll see the brass colored 'U' clip. Make sure you zip tie those wires to the pedal arms. Good luck. Oh yeah, disconnect the battery...to be safe.
butnut
Old Sep 15, 2002 | 02:40 PM
BTOWN4RUNNER's Avatar
Yeah, I would say that or even the power source for your gauges. You can take the cluster apart and see what is back there for when you get the gauges, and then tape there, like you will do for the gauges. Let us know how everything turns out! :fireman:
Old Sep 15, 2002 | 07:19 PM
sleepy1405's Avatar
I don't want to wait that long, at the rate we're going at we'll never get those gauges.......:cry: , anyways so where is the astray light thingy??? I need pictures or someone could help me and we could take pictures and put them up here....I feel a PROJECT coming on
Old Sep 15, 2002 | 07:39 PM
runninclean's Avatar
I have these same pedals and I hooked my up with the parking light fuse. The only problem with the ash tray/cigarette lighter hook up is that it is on anytime the car is on. You may or may not want this. Also make sure the pedals fit because my pedals were too small and the brackets did not hold them on and they ended up falling off three times before I took them off because of the safety concern. I haven't had the time to rig something up with the brackets to make sure they stay yet. Just another concern you may want to think about. Good luck
Old Sep 15, 2002 | 07:48 PM
Old Sep 16, 2002 | 06:07 PM
sleepy1405's Avatar
I didn't know my ashtray light was on all the time the car was on......you sure about that? I thought it was only when the rest of my lights were on since I have DRL, like when I turn my parking lights on..... I will go and check on that.
Old Sep 16, 2002 | 07:35 PM
I was mainly referring to the cigarette lighter wire. I have my neons hooked into this and this is definitely on all the time. Pretty sure you know that already. I'm not really sure about the ashtray light either.
Old Sep 17, 2002 | 12:26 AM
mark from uk's Avatar
the light in the ash tray on mine comes on with the lights and it is a good place to tap in to for foot well lights in the back
Old Sep 17, 2002 | 07:49 PM
sleepy1405's Avatar
so does someone want to take a picture of how you have your pedals hooked up or is that too hard?? I wanna see what it's supposed to look like and work better with visuals.
Old Sep 17, 2002 | 09:11 PM
NerfHerder-97SR5-'s Avatar
Sleepy dont install glow pedals!
Booooo on glow pedals!!
Booo on Altezza Lights!!!
Boooooo on ricers!!
BOOOO!!
Old Sep 17, 2002 | 09:46 PM
RTdawgs's Avatar
Boooooo on ricers!!
BOOOO!!
i second that.
Old Sep 17, 2002 | 09:52 PM
prerunner guy's Avatar
hook them up to a separate switch. that way you can turn them on and off at your pleasure.
Old Sep 18, 2002 | 07:00 PM
sleepy1405's Avatar
I like the switch idea, but how the heck do I do that!
and I want to put the pedals on because I think their nice looking....I got them on ebay so check out the item #1859050289
Old Sep 18, 2002 | 07:05 PM
a switch is really easy to run. If you want just a regular switch all you have to do is have whatever power wire you're running lead into one feed, and a wire running from your switch to your pedals power wire. If you want a lighted switch then the only differences is that you have to run a ground wire for the switch because it is lighted. If you have any ques. let me know cause I've hooked up plenty of switches in my day.
Old Sep 18, 2002 | 07:40 PM
jx94148's Avatar
I want a light up steering wheel. Where can I but that?
Old Sep 21, 2002 | 09:33 PM
sleepy1405's Avatar
they are on right now, but i haven't hooked up the glow part yet....might wait and get someone else to do that....not comfortable doing it myself.
nvdesertrunner
May 11, 2020 08:18 PM
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
PopsDad1
Jul 30, 2015 02:21 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
