Disable DRLs on 3rd Gen.
Old Oct 26, 2003 | 01:03 PM
RawRunner's Avatar
How do you disable your Daytime Running Lights on a 3rd Gen. 4runner? I know they don't come on if your e-bake is on. Is there some way to trick the system through that? Any info would be great.
Old Oct 26, 2003 | 02:12 PM
Bighead's Avatar
Disabling the Daytime Running Lights (3rd Gen)
This is the only other way I know of.
CTB's Avatar
CTB
Try a search on this board - you will find the information you need.
Old Oct 26, 2003 | 03:26 PM
RawRunner's Avatar
Thanks for the information. I just did it and it took 1 min. I didn't think it would be that easy to do.
Old Oct 2, 2004 | 04:58 PM
kevin444's Avatar
is there a writeup for the 00" model. Cuz the writeup doesnt quite apply to me.
Old Oct 2, 2004 | 07:04 PM
pfdaxe's Avatar
Just uplug (grey plug) the resistor next to the battery (small vented box between the batt and fender). That'll work on an '00
Old Oct 3, 2004 | 07:50 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Ditto. The plug is to the contraption bolted to the inside driver's side fender by the battery in the '00. The TSB DOES apply to the '00, but it's a lot more trouble than simply unpluging a connector, plus, disabling via the connector is easily reversible. I keep mine plugged in, but I'll unplug it for the drive-in theater, campground, etc., when you don't want your DRL's operable at night.
Old Oct 3, 2004 | 07:51 AM
kevin444's Avatar
thank you!
Old Oct 3, 2004 | 08:11 AM
Rick F.'s Avatar
Here's a pic of mine...
http://img.photobucket.com/albums/v4...5/DSC00536.jpg
Old Oct 3, 2004 | 10:31 AM
4x4taco's Avatar
what about for a '00 tacoma? i looked under that dash but am not sure where the relay is down there
Old Oct 4, 2004 | 05:37 PM
4x4taco's Avatar
i was just moving this back up to the top, does anyone know for a '00 tacoma?
LittleUgly
15
Jan 2, 2020 01:30 PM
Flightguy
Oct 2, 2015 05:34 PM
voiddweller
Oct 2, 2015 07:47 AM
Rickstwowheels
Sep 29, 2015 02:23 PM
charlie_fong
Sep 27, 2015 10:06 PM
