DIFF size
Old Apr 9, 2004 | 12:53 PM
DIFF size
I have a 2000 4runner auto v-6 whar are my diff sizes?
Old Apr 9, 2004 | 01:21 PM
Dr. Zhivago's Avatar
Away
8" 4 Pinion Rear
You need 8" V6 Gears and Lockers for the Rear. You CAN'T use Gears and Lockers designed for the Tacoma/T100/Tundra Rear. You CAN use Gears and Lockers designed for the older 4Runners and Trucks with the 8" Ring Gears as long as they are for the V6 4 Pinion Diff.
7.5" Reverse Rotation Front
You CAN use Gears and Lockers that fit the Tacoma Front Diff for the Front. You CAN'T use Gears and Lockers designed for the Standard Rotation 7.5" Front Diffs.
Hope this helps.
G
Old Apr 9, 2004 | 04:00 PM
Dr.Z thanks for the reply. the info was just what I need, as Im about to completely regear w/ front and rear ARB's. I dont want the install held up because the wrong gears were shipped.
Thanks AG
Old Apr 9, 2004 | 07:14 PM
toy283's Avatar
When did they start putting reverse rotation gears in the front of 4Runners? AFAIK, they exist only in FJZ80 (and maybe 100) Landcruisers.
Old Apr 9, 2004 | 08:28 PM
Away
The Taco's and 4Runner's both use reverse rotation gears in the front. The 7.5" gears that they use are not interchangeable with other Toyota 7.5" diffs.
I have never heard anything to the contrary.
G
Old Apr 11, 2004 | 06:14 PM
Flygtenstein's Avatar
You can use lockers for the standard rotation front ends, either that or my RD90 is really confused. I have standard rotation in my 95 and everyone else with a 96-2002 has reverse, but the same 7.5" diameter and carrier.
The start of reverse rotation in 4-Runners was 96.
Old Apr 11, 2004 | 08:23 PM
Away
I meant to specify 3rd Gen 4Runners in my last post...
G
punks_is_4x4
May 31, 2016 06:03 AM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
gp66
Sep 7, 2015 08:29 AM
viesail
Sep 5, 2015 04:23 AM
moparbay
Sep 3, 2015 12:48 PM
