Denatured alcohol?
Old Dec 31, 2004 | 10:46 AM
ttr125mar's Avatar
Denatured alcohol?
I searched about cleaning throttle bodies but everyone said to clean it with carb cleaner, well I have some denatured alcohol here and was wondering if this is a good idea to clean the throttle body with this or is this stuff to strong? Just curious I use this to clean my little r/c engines and it does a very good job.
Thanks,
Mario
Old Dec 31, 2004 | 11:05 AM
mike_d's Avatar
Thanks,
Mario
it should be fine. it may dissolve some of the rubber hoses and stuff, so be careful about that. but out here in colorado where we run 15% ethanol in our gasahol and everything is fine. in fact i bet ethanol is more gentle than carb cleaner.
Old Dec 31, 2004 | 06:05 PM
Mikey's Avatar
break down and buy the throttle body cleaner. I hate the thought of taking a chance and damaging a sensor.
Old Dec 31, 2004 | 08:20 PM
gwhayduke's Avatar
Denatured alcohol is just ethanol with a little bit of methanol added to make it extra poisonous. You can use it on your TB but you'll be disappointed with the results. TB cleaner is a much better solvent.
Old Dec 31, 2004 | 09:07 PM
Ironmike4x4's Avatar
It should be fine. We've used it for cleaning out the A/C lines at work.
Sorriso
Aug 24, 2017 09:59 PM
saphirekosmos
Jun 22, 2015 10:26 AM
elnido
Apr 22, 2005 07:48 PM
The Dutch Man
7
Jun 11, 2003 01:56 PM
