Deckplate mod...Need Help???
Old Apr 1, 2007 | 12:31 PM
4runnersurf's Avatar
This is my first post, so I'm somewhat of a newbie to these forums, but not a newbie to Yotas.
I just completed the deckplate mod and I revved up my engine when I was finished and my engine stalled. I put the deckplate in and no stall. Any explanations to as to why this happened?
Old Apr 1, 2007 | 01:02 PM
kevin444's Avatar
give the ecu a reset?
clean the maf?
Old Apr 1, 2007 | 01:05 PM
MTL_4runner's Avatar
^^^ Ditto.
The ECU needs to relearn, pull the neg batt terminal for 1 minute and try it again.
I bet it won't stall with the deckplate out after that.
You should probably clean the MAF soon as well.
Old Apr 1, 2007 | 01:37 PM
How do you clean the MAF???
I had the neg battery pulled while I was doing it. Should I still reset the ECU?
Old Apr 1, 2007 | 03:01 PM
Elton's Avatar
maf sensor is real easy to clean just take it out spray with electrical contact cleaner and let it dry for a few mins also double check all the wiring
Old Apr 1, 2007 | 03:09 PM
Use brake cleaner on the MAF, works alot better.
MAF cleaning:
http://www.4x4wire.com/toyota/mainte...tenancep5.html
Once you pull the neg batt terminal, the ECU has been reset.
Old Apr 1, 2007 | 03:43 PM
Thanks for the quick replies. Works great.
Old Apr 1, 2007 | 03:46 PM
Elton's Avatar
also welcome to yotatech and happy april fools
rimpainter.com
35
Jul 16, 2003 08:41 PM
calrockx
Apr 20, 2003 09:08 PM
Bob_98SR5
Apr 8, 2003 10:14 PM
ryan k
14
Mar 6, 2003 12:29 PM
