dash crack help
I just emailed the seller of the dash assembly he doesn't have one on hand himself but is able to get one and he would like to know what color. Would you like me to email back or deal with him directly? Here's the link
http://contact.ebay.com/ebaymotors/w...lerQuestion_VI
#25
you might try some two part epoxy or something like that to fill the crack and sand it down smooth with some 1500 grit and then prime and paint. I mean it sounds like you really have nothing to lose at this point if it don't work you can go back to the buy a replacement plan.
Just a thought ....
Just a thought ....
#26
I KNOW HOW TO FIX THEM !!!!!
Iteams needed.
JB Weld
Sandpaper
Velcro
Vinyl Spray paint
When the dash cracks it likes to rais up like this ^ right along the crack. You need to carefully sand this down even thought it opens up the crack wider.
Mix the JB Weld as normal, and apply to the crack like spackel.
Dabbing the velcro into the JB weld gives it the perfect texture that matches the rest of the dash. You might have to exsperiment and let your artistic side out a little but it is easy to do. Even though JB Weld is thick, it tends to smooth itself out so you have to let it set up for a while before you can texture it. Don't be surprised it you come back and the texture is gone if you dont baby sit it.
After it dries paint it. Use the Vinyl Dye Spray paint, it will coat cover and wear much better than regular paint, or plastic paint. It also has the right look, neither real glossy or flat.
Iteams needed.
JB Weld
Sandpaper
Velcro
Vinyl Spray paint
#27
I would think the epoxy would work a little better than JB weld, but I'm not sure. i have a small crack in my dash on the passenger side. If I try to fix it this way I'll be sure to get some pictures and we'll see how things go.
zz_denis
Sep 6, 2015 03:43 PM
May-39
Sep 6, 2015 01:05 PM
