dash crack help
Old Oct 25, 2005 | 06:24 PM
Dublin's Avatar
I just emailed the seller of the dash assembly he doesn't have one on hand himself but is able to get one and he would like to know what color. Would you like me to email back or deal with him directly? Here's the link
http://contact.ebay.com/ebaymotors/w...lerQuestion_VI
Old Oct 30, 2005 | 04:26 PM
red90runner's Avatar
does anybody know how hard it is to replace the whole dash? I might be getting a pulled one from a junker and just was wondering on installation stuff.
-Pat
Old Oct 30, 2005 | 04:37 PM
Babypig's Avatar
Man i just threw one out that you coulda had for the shipping just to get it out of my hair.
Old Oct 31, 2005 | 01:36 PM
damnit, that sucks man. Whatever. Anybody else
Old Nov 6, 2005 | 11:07 AM
  #25
gunbunny's Avatar
you might try some two part epoxy or something like that to fill the crack and sand it down smooth with some 1500 grit and then prime and paint. I mean it sounds like you really have nothing to lose at this point if it don't work you can go back to the buy a replacement plan.
Just a thought ....
Old Nov 6, 2005 | 05:08 PM
  #26
phorunninduke's Avatar
I KNOW HOW TO FIX THEM !!!!!
Iteams needed.
JB Weld
Sandpaper
Velcro
Vinyl Spray paint
When the dash cracks it likes to rais up like this ^ right along the crack. You need to carefully sand this down even thought it opens up the crack wider.
Mix the JB Weld as normal, and apply to the crack like spackel.
Dabbing the velcro into the JB weld gives it the perfect texture that matches the rest of the dash. You might have to exsperiment and let your artistic side out a little but it is easy to do. Even though JB Weld is thick, it tends to smooth itself out so you have to let it set up for a while before you can texture it. Don't be surprised it you come back and the texture is gone if you dont baby sit it.
After it dries paint it. Use the Vinyl Dye Spray paint, it will coat cover and wear much better than regular paint, or plastic paint. It also has the right look, neither real glossy or flat.
Old Nov 18, 2005 | 06:09 AM
  #27
bob200587's Avatar
I would think the epoxy would work a little better than JB weld, but I'm not sure. i have a small crack in my dash on the passenger side. If I try to fix it this way I'll be sure to get some pictures and we'll see how things go.
Old Nov 24, 2005 | 08:27 AM
  #28
thanks for the help guys. Do you think I should pull the dash out to do this. It would probably make it easier, but should I?
-Pat
Old Nov 26, 2005 | 07:21 PM
  #29
Nix_Toy's Avatar
Just revinyl the thing. That's what I'm going to do. Smooth out all of your cracks, then glue a new piece of vinyl over it.. bam, you're done!
Old Nov 28, 2005 | 01:48 PM
  #30
hmmm, not a bad idea. But I think there are alot of places where things could go wrong. Just my .02 thanks anyway
-pat
Old Nov 28, 2005 | 03:04 PM
  #31
82Yoda4x4's Avatar
hmmm , looks like part #2 on the first link is your dashboard - but, they're calling it a crash pad, and charging a little over $500.....
pickle6415
Dec 25, 2015 07:34 PM
Obmi
Nov 24, 2015 11:37 AM
Streetrod19772000
Sep 10, 2015 06:22 PM
zz_denis
Sep 6, 2015 03:43 PM
May-39
Sep 6, 2015 01:05 PM
