Da Da Da DECK PLATE!!!
Old May 20, 2003 | 08:42 PM
ssbogger's Avatar
Well I did it today and I am very happy. My hat is off to the person who discovered this mod. I had a hard time finding the plate. I went to 4 different marine stores and none ofthem had one in stock. I had it ordered and picked it up today. It was white so I painted it black to look better when installed. It does make a throatier sound when you get on it from about 3500 rpms and above. I couldnt notice any sound difference below that. I could definantly notice a difference in acceleration. All in all this mod rules and I highly reccomend it to everyone.
I wasted about a quarter tank of gas driving around today just so i could hear it roar!
Old May 20, 2003 | 10:03 PM
Tacoma Dude's Avatar
I haven't been able to set aside a good amount of time to do this mod but am eagerly anticipating the day that I do
I'm jealous ssbogger
oh yeah, I'll probably end up using a whole tank just jump accelerating out of every red light I get to
Old May 20, 2003 | 10:13 PM
midiwall's Avatar
fwiw, I found (what I think is) a new source for deckplates, and they're a bit cheaper than another online source that I've seen posted here. $6.69 for a 4" black, $4.95 shipping:
http://www.shipstore.com/ss/html/RAB/RAB4LB.html
Obviously the tax on something like this will be less than the shipping, so it's worth it to call around locally first.
ssbogger: The next thing you should go after is the ISR mod!
https://www.yotatech.com/~corey/tech...ntake/dr_z.htm
Mark
Old May 20, 2003 | 10:28 PM
Try it with a high flow air filter like a K&N or Amsoil! mmm, good!
Old May 21, 2003 | 06:24 AM
DSP's Avatar
DSP
I just recently did mine as well.
My house sits at 8750 feet above sea level...
I did the mod for the shear fact that my engine was starving for oxygen at this elevation.
Since the MOD I have noticed better Accel.
However more important to me was the ability for the car to hold it's RPM's when going up hill. I don't have to downshift nearly as early now that the mod is complete. Also when I do downshift going up hills like Dallas Divide I tach much lower (In the 3,000-3,500 range instead of 3,500-4,500).
If you do this mod I highly suggest finding or borrowing a dremmel since it makes cutting the hole a cake walk.
Thanks for the reccomendation YotaTech.
I'd still be stock without you...
Can you say "big lump in my throat..."
Later
Old May 21, 2003 | 06:31 AM
DSP - I wish I was in Telluride. ahhh dreaming........
Old May 21, 2003 | 06:35 AM
amorphous's Avatar
6"!
here's a link for anyone that wants a 6" deckplate!:
http://www.shipstore.com/ss/html/RAB/RAB6LB.html
and more:
http://www.overtons.com/cgi-bin/overtons/setcat.cgi?2
bling bling version?:
http://www.go2marine.com/frameset.js.../86155F/&df=41
~a
Old May 21, 2003 | 06:51 AM
DSP's Avatar
DSP
Ooops, sorry forgot attachment!!
Old May 21, 2003 | 06:52 AM
DSP's Avatar
DSP
here is a snap for your daydreaming....
Old May 21, 2003 | 07:09 AM
midiwall's Avatar
That was just cruel!
Old May 21, 2003 | 07:27 AM
DSP's Avatar
DSP
Sorry Bro...
No malicious intent...
I am still waiting for the darn trees to bud...
You know how sick of winter I am already...
Not trying to be cruel in Telluride
DSP
Old May 21, 2003 | 08:30 AM
DSP - being down below you a bit I can tell you, do the ISR mod as well! The deckplate does wonders for letting more air in (important out here, there isn't much to go around) but the ISR will let that air speed up. When it's less dense to begin with it makes a huge difference, since atmospheric pressure isn't helping you as much out here.
Old May 21, 2003 | 08:34 AM
Cruel. ahhhhhhhhhhh. I love Telluride.
Thanks for the picture. Hopefully I will get out there this summer.
Cheers.
Old May 21, 2003 | 10:38 AM
ssbogger's Avatar
What are some other options for the ISR mod for tubing other than having a muffler shop expand a 2.5'' pipe.? Is there no place that sells some sort of rubber tubing that can be stretched around it?
Old May 21, 2003 | 12:25 PM
92runner's Avatar
This may be a stupid question but....when the deckplate cover is on the airbox how does the engine get air? The point is to seal it off so water doesn't get in but I assume the air would also be sealed out. What am I missing here? Thanks.
Scott
Old May 21, 2003 | 01:15 PM
rimpainter.com's Avatar
Scott
The air comes in through the stock snorkel in the passenger fender well.
Old May 21, 2003 | 01:28 PM
I think some people have found suitable alternatives at Home Depot but I couldn't tell you what they were. Try a search on the forums for it, I'm sure the info will turn up.
Old May 21, 2003 | 01:32 PM
ssbogger may have a different intake design than earlier models...
but, if not, then you can use plumbing end caps from Lowes or Home Depot like denverbikeguy said. My sig contains some threads regarding the topic. There are also a couple pictures to help you along.
Old May 21, 2003 | 02:32 PM
I was talking more about a pipe in the middle - remember he has the newer intake design, with the two rubber hoses and the resonator in the middle. I thought someone found a piece of something hollow that would work (some kind of PVC maybe?) without needing to get a custom pipe made. I can't really remember. Might have even been that one that looked like crap, now that I think about it.
I agree, finding a piece of rubber hose that works for this would be best... Ahh, the quest goes on!
FWIW I have the older intake style like you 96_runner, but I am going to get the two hoses from a newer model with something in the middle and go that route, just to make it a little neater. Need to see what I can find lying around local wrecker yards...
Old May 21, 2003 | 03:00 PM
Yeah, looks like this thread is merging...
