cylinder 5 mis-fire, where to start?
Old Aug 29, 2003 | 10:18 AM
Joec500's Avatar
Well my buddy Daryl pulled the codes from my 1996 Limited and apparently Cylinder 5 is misfiring. (92,000 miles)
Where would you guys start? Should I replace the plugs? wires? clean injectors?
thanks
Joe
Old Aug 29, 2003 | 10:37 AM
AgRunner06's Avatar
Post
Do a complete tune-up on it and I bet the code doesn't return. You will also have to have the code cleared from the computer.
Good Luck
Old Aug 29, 2003 | 10:48 AM
Joec500's Avatar
in your opinon what does a complete tune up involve?
Old Aug 29, 2003 | 10:53 AM
PhxTRDRunner's Avatar
..Change plugs/wires and you'll be ok most likely. If not, then you may have a dying coil pack.
Old Aug 29, 2003 | 11:02 AM
Dr. Zhivago's Avatar
Away
Believe it or not, this code can also indicate a vacuum leak... Do a careful search for cracked or disconnected hoses.
Hope this helps.
G
Old Aug 29, 2003 | 11:06 AM
Joec500's Avatar
Doc Z....there are a number of hoses in this dam engine compartment, I checked them all over just to make sure, that there is no leak. Also the engine def runs funny....Rough Idle right off the start. Also when the Cyclinder 5 is disconnected....the Engine seems to be unaffected (i.e. still runs like crap) But when I pull a good Bank the engine gets even rougher.
Joe
Old Aug 29, 2003 | 11:34 AM
Away
Joe,
Well, the fact that you can pull Cylinder #5 and it doesn't affect the engine indicates that that spark plug is definitely not firing.
Take the #5 wire and hold the end of it while the engine is running, with insulated grips of some sort, next to a ground source to see if you get a spark on the wire itself. That will rule out the wire at least if you get spark.
Also, if you have access to a multimeter, check it for continuity. If no spark and the wire has continuity, you can suspect a bad coil pack, although that is a rarity.
There are procdures for testing the coil packs. I'll fill you in on those after you perform the above tests.
Post back with your results.
G
Old Aug 29, 2003 | 12:43 PM
MTL_4runner's Avatar
Sounds like G has ya covered.
You'll get it solved pretty quick now that you have isolated it as electrical and limited to the #5 cylinder!
jerusry
Oct 19, 2015 05:28 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
