CV's Binding?!
Old Nov 19, 2007 | 06:06 AM
Nate08's Avatar
CV's Binding?!
So I've had my driver side Inner CV Boot split for about 3 months now. I put more grease in it yesterday, but both CV's are still popping. I'm replacing with the NAPA CV's. Is their anyway I can make them stop until I have the new Cv's?
Old Nov 19, 2007 | 06:35 AM
mkgarrison5's Avatar
nope they are broke. will do it until its replaced. be careful! when they go, they go.. good luck... btw why napa? whats wrong with yota oem?? mine has 100k miles and works like a charm
Old Nov 19, 2007 | 06:43 AM
Bighead's Avatar
Price.
Old Nov 19, 2007 | 07:34 AM
MillerPKA's Avatar
quality first. especially when dealing with those on a lifted truck. unless you go advance auto...get their crap cv's and when they break every week you can replace them for free
Old Nov 19, 2007 | 07:36 AM
mjwalfredo's Avatar
I believe NAPA has the lifetime warranty on their CV axles as well.
Old Nov 19, 2007 | 07:59 AM
how much are the cv's from napa with the lifetime warranty?.. also from someone who told me this at work, that if you offroad and it shows they will not warranty them.. just figured i would say that..
Old Nov 19, 2007 | 08:23 AM
Nate08's Avatar
They are $70. What Napa doesnt know wont hurt them . Went and priced OEM ones at $416 EACH! Quick question, I can still engage 4WD, would that still make them broke?
Old Nov 19, 2007 | 09:13 AM
if they are popping then they are broke lol.. replace them
Old Nov 19, 2007 | 09:25 AM
cackalak han's Avatar
Well, anytime you see a rip in the boot, you're pretty much going to have to buy a new one or try to rebuild the old (not recommended). Dirt gets into the joint and gradually wears out the parts. No way to fix that unless you completely rebuild or replace.
I've used NAPA axles before (not the reman'ed but NEW). They held up solid. Autozone axles are good, too (again, new). But I believe they both sell the same axles from the same manuf.
Old Nov 19, 2007 | 09:51 AM
Nate08's Avatar
Supposedly these are the NAPA Name Brand. Are GSP's any good? I'm not saying they aren't broke, it sounds in person like they are, haha . I just dont' understand how if they are broke, how they can still engage in 4 WD.
Old Nov 19, 2007 | 10:00 AM
seanz0rz's Avatar
Guest
well they arent broke broke, they arent snapped in half. which boot ripped? im going to guess the outter. something is broken inside the joint, it will still work as a cv, but it really is a ticking time bomb with load applied in 4wd.
i dont see that you have manual hubs, so im assuming you have the ADD still in place. this will cause the cv's to spin even when not in 4wd.
Old Nov 19, 2007 | 10:06 AM
Nate08's Avatar
I don't have manual hubs and it's the inner-joint on the driver side.
Old Nov 19, 2007 | 10:23 AM
seanz0rz's Avatar
Guest
do you have a diff drop with your lift? in my opinion that is absolutely necessary with any lift.
as for the popping of the joint, the inner joints are pretty simple (not nearly as complex as the outers) not sure what component in there would be popping.
how long do you have to wait for the part? seems like it should be only a couple of days if they were not in stock to begin with.
Old Nov 19, 2007 | 10:25 AM
Nate08's Avatar
I have a 1" diff drop. As for the part, I'm pretty sure NAPA has them in stock. But I went for 1.5 months and wheeled it once on a decent trail without the drop. I just hope replacing it will fix it.
Old Dec 2, 2007 | 06:48 PM
Nate08's Avatar
Well...they have been replaced. I still have a popping. My custom panhard bar has really big thread (it is a tool made for a crane) so the threaded part can play about 1/8" when the back articulates. I think this is causing tthe popping, however, it seems to be coming from up front. I know that vibrations and sound can transfer causing a mental fart, but, anyone have any ideas? I'm going to make a new panhard with very fine thread.
Old Dec 3, 2007 | 12:18 AM
hopper's Avatar
Could be from the steering wheel. If you search here and ttora you should find a lot of info. Basically the slip joint has play and thats what you hear.
Old Dec 3, 2007 | 03:29 AM
Nate08's Avatar
The pop from the front seems to be coming dirctly underneath where the gas/brake pedals are. Especially when I sway from side to side. can I just use some kind of synthetic grease on all zerks? And I just put grease in until it starts to come out of the zerks, correct?
Old Dec 3, 2007 | 04:55 AM
toy_tek's Avatar
Check all your bushings up front, starting with the sway bar bushings. Mine were shot and basically missing thus allowing the bar to contact the frame. Could be something like that causing the noise you're hearing. Jack up the truck, get a long pry bar or pipe, and pry on stuff to see if anything is moving more than it should.
Old Dec 3, 2007 | 09:32 AM
5-spd for life!'s Avatar
Mine pop but it is the bushing on the Mcpherson strut. It pops over every bump that I hit and can do nothing about it until a new strut or bushing is replaced... So I said SAS!!! Thats where I am now.
Check you rubber on your strut bushing and if it is cracked or punctured then that is probably it. A lift puts so much extra force in that one part.
Old Dec 3, 2007 | 04:16 PM
hopper's Avatar
If its from under the dash/ pedals I would put money on it that its the steering slip joint. The joint gets to much play in it and you get the clunk.LOOK and read The only fix is to weld the slip joint or put a pin in it. Either way that is a big safty part your working on (if you hit the steering wheel with your body it will calapse and make less impact on your body.)
