cricket noise from engine at idle
Old Jan 20, 2008 | 06:48 PM
Skrillah's Avatar
Yeah, I'm in the ticking group too....
Someone has to know how to get this fixed?? Maybe just the thread title is throwing off the heavy hitters to chime in...
Old Jan 20, 2008 | 09:49 PM
2000t4rAKS's Avatar
That's what I wasn't sure about because my problem is also a TICKING not a buzz. I think I jumped to a quick conclusion when I saw posts of the charcoal canister. I definitely know that it is coming from the EVAP system (the black box) near the fender wall because I put my finger on it and can feel the ticking going on inside. I would figure that someone on here has to know but nobody has chimed in yet. Maybe we should start a new thread with the word "TICKING" in it????
Old Jan 21, 2008 | 06:23 AM
Skrillah's Avatar
I know mine is from the evap system but its hard to tell exactly which component. Check this stuff out...
Warranty for EVAP?
http://www.tundrasolutions.com/forum...evap-warranty/
Old Jan 21, 2008 | 07:38 AM
skshepherd's Avatar
I had ticking/knocking
It took a while to find mine but it was because the crankshaft pulley was not torqued down properly at the last TB change and had loosened. The noise was the pulley wobling. I remember reading that toyota changed the recommended torque value to a higher one to prevent this. If it gets too loose then it can move and twist the key that holds it in place. Just a thought. I think I had put a previous post when I had fixed mine that describes the problem I had in more detail. Good luck.
Old Jan 21, 2008 | 08:02 AM
  #25
Skrillah's Avatar
Hmm...check this out guys...?
http://www.toyota-4runner.org/showth...?threadid=8592
Old Jan 23, 2008 | 05:15 PM
  #26
bwhyit's Avatar
If someone can tell me how to post a PFD of JPEG file on here I'll attach a copy of the TSB.
Old Jan 23, 2008 | 05:26 PM
  #27
AlecHMB's Avatar
I have a '99 manual, I too have the "cricket" noise. It is my clutch bearing. It just needs to be tightened. No big deal, if it bothers you, have it tightened, if not let it be.
Charecter1
Nov 6, 2023 10:08 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
Gamble_STi
Jul 7, 2015 07:54 PM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
