Craptastic idle
Old Nov 30, 2004 | 02:53 PM
desert whomper's Avatar
Craptastic idle
ok in the on going search for my crappy idle, i think it might be my distributor, it looks original and my truck has 226 k miles on it. its a 91 22re truck. I took apart my distributor and it idles alot better but when i give it gas it idles at about 650? no tach and then slowly goes to 700-780 rpm about 5 seconds later and my truck always smells rich too. I just replaced the O2 sensor.
Old Nov 30, 2004 | 02:54 PM
jimbo74's Avatar
are all the settings adjusted right? i kow you have efi, but my truck is a carb and has a mixture setting, idle speed screw, and a fast idle screw...
Old Nov 30, 2004 | 02:56 PM
i only have idle speed, and idle air by pass screw and to my knowledge there are set right but if anyone has a certian procedure it would be great since i havent found any for the idle air screw.
Old Nov 30, 2004 | 08:48 PM
ok i decided to check my timing chain, seems like there might be too much slack, dont now if its ever been replaced, also the cam sprocket has that dent on it, i made sure the #1 piston was TDC and the dent wasnt all the way to the top, a lil to the left, almost seemed like 1 tooth off, heres a art pic until i take a real picture. any suggestions?
File Type: bmp
Old Nov 30, 2004 | 09:08 PM
SoCal4Running's Avatar
The cam sproket is not a tooth off when the dot is a little to the left, thats just how they are. If youv'e got 226K on the chain I would change it whether its the problem or not. Kinda sounds like your cold start injector might not be tuning off. Hows the MPG?
Old Nov 30, 2004 | 09:11 PM
um last time i check i think it was around 260 miles on about 6/8 or 7/8 of a tank cant tell really cuz my fuel gauge is off, but it always smells rich but i dont know if its the cold start injector because it warms up and then the idle does drop, if i disconnect it could that tell me if it is bad?
Old Nov 30, 2004 | 09:22 PM
Well if your getting 260-300 per tank on 31's thats probably not the problem. How long since you last checked/adjusted the TPS and cleaned out the TB?
Old Dec 1, 2004 | 12:54 PM
i just redid all of that new gaskets, cleaned injectors, cleaned tb and intake plenum and manifold and adjusted tps.
Old Dec 1, 2004 | 10:09 PM
i disconnected my cold start injector seemed to help alot, now can it e the thermostat that tells teh temp for the inkector or the injector itself?
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
GrimWolf
Aug 28, 2015 03:36 AM
noosh
Aug 21, 2015 03:49 AM
Sarcazmo
Aug 15, 2015 08:22 PM
