Crankshaft Bolt
Old Dec 1, 2003 | 12:04 PM
ricoace's Avatar
Crankshaft Bolt
I have a little 94 Toyota 4*4 pickup 4 cylinder. I am trying like he** to remove the crankshaft bolt! ...It wont budge! I have even put a hydralic jack undernieth the cheater bar and all it does is pick up the truck off the ground! What the?
can any body tell me what gives with this bolt? is it a counter threaded bolt?...any body please
Old Dec 1, 2003 | 12:40 PM
ricoace's Avatar
BUMP!
Old Dec 1, 2003 | 01:34 PM
rimpainter.com's Avatar
You realize how much torque it takes to get that off right?
If you dont have an impact gun, then you are going to have to use the motor itself to pop it off. I would explain how to do it, but it really would be best that you had a mechanic there with you.
It basically involves cranking it over with the breaker bar in place.
Old Dec 1, 2003 | 07:18 PM
ricoace's Avatar
A whole lot of torque I know.I have taken a hundred of those bolts off in my years, never one like that one. Tried the Engine Method earlier today and it worked like a breeze. Thanks for replying.
Old Dec 2, 2003 | 06:21 AM
Toddski's Avatar
I just did my water pump on my '88 and ran into the same situation.
I too was stumped then my father-in-law came up with an idea.
What he did was use a 4 foot bar (actually it was the bar from his floor jack) and some rope.
The rope diameter is small enough to fit in the groove of the pully.
We fed the rope down the bar, wrapped the rope around the pully several times then fed it back up through the bar and secured the end of the rope.
We rested the bar up against the frame to hold it in place.
We used a good impact wrench socket.
When you start to break the bolt, the rope will tighten up along the pully.
It took me about 10 minutes but it finally broke loose.
Hope this helps.
Old Dec 2, 2003 | 09:13 AM
MTL_4runner's Avatar
Use a 2 foot chain wrench (be sure to protect the pulley).
Then use about a 4 foot length of pipe over a ratchet.
You can generate alot of torque with those two lever arms!
Does still take some arm strength though.
Old Dec 2, 2003 | 10:52 AM
Gadget's Avatar
Great, glad to hear that you got it off.
Now, what is your plan for retorque that bolt on reassembly.
Gadget
www.URDUSA.com
Zach_trun
Jan 22, 2020 04:42 PM
Obmi
Nov 24, 2015 11:37 AM
Corvoid
Sep 14, 2015 10:10 AM
Pocoyota
Sep 8, 2015 02:41 PM
Jwp1
Sep 6, 2015 11:03 AM
