crank pulley
Old Sep 25, 2003 | 11:18 AM
884runner's Avatar
crank pulley
the crank pulley on my 3.0 won't stay on. When ever i turn on my engine the bolt that holds the pulley to the crank unscrewes. the bolt is not stripped or anything so i'm guessin is a harmonic valance(spelling) problem.when i tighten the bolt back on it get's as tight as it can but then when i start the engine it becomes loose again and the pulley starts to come off and hits the fan making a pop corn sounding noise and then the belts come off. Is there any way to fix this at home or do i gotta tow it somewhere? thanks
Old Sep 25, 2003 | 11:23 AM
rimpainter.com's Avatar
You mean harmonic balancer. Anyway, the bolt you are attempting to tighten has an insane torque requirement. Are you going by the factory specs? Are you using a torque wrench or what?
I cant remember what it is, but I know it's one-hundred something.
Old Sep 25, 2003 | 02:09 PM
growinseed's Avatar
The 22R is 116ft/lbs
Old Sep 25, 2003 | 05:40 PM
Marc's Avatar
the 3VZ-E is 181 ft. lbs according to my Haynes and Chilton manuals
Old Sep 25, 2003 | 07:24 PM
884runner's Avatar
hmm
how do you fit a torque wrench where the bolt is b/c the fan and radiator are right infront of it. do i have to take all of that off too. and is there supposed to be like a bearing or something between the bolt and pulley so the pulley doesn't unscrew the bolt?
Old Sep 25, 2003 | 07:59 PM
Tech's at Toyota go from the bottom, and use an air gun then a torque wrench.
Dont forget, most of this stuff was designed to be accessed via lift.
Old Sep 25, 2003 | 08:09 PM
Firefyter-Emt's Avatar
Yep.. Find a shop that will hammer it back in with lock tight and an impact gun.. Most impact guns, wide open, will not hammer the bolt in too tight. It is next to impossiable to tighten without the proper SST to hold the crank still.
Old Sep 26, 2003 | 04:14 PM
Reed23's Avatar
I would definately pull the fan, it should only be 4 10mm nuts, after that just make sure you have a good T wrench
Old Sep 26, 2003 | 05:26 PM
Actually at our shop we do not use an impact gun unless the radiator happens to be out (I don't remove the radiator for this) or the engine is on a stand. I use a chain wrench (with a cut section of a drive belt to protect the pulley) and a 1/2 inch torque wrench (or breaker bar) and a 19mm shallow socket. If your truck happens to be a 5 Spd, you could put it in high gear, set the parking brake and this would do the job of the chain wrench. Hope this helps.
Old Sep 28, 2003 | 05:06 PM
884runner's Avatar
thanks
thanks guys, but do you think it would be better if i just towed it somewhere and let them do it b/c i don't think i will be able to properly tighten the bolt tight enough.
Old Sep 28, 2003 | 08:49 PM
oly884's Avatar
Guest
I'll put it this way, I almost pulled my back out to tighten my crank pully to 181 ft/lbs. There is a trick to it, you need the crank pully holder. It's really hard to explain how it works, I went to a toyota dealer and borrowed one of theirs.
Old Sep 29, 2003 | 03:03 AM
MTL_4runner's Avatar
You will probably need a pipe extension on both the chain wrench and the ratchet to get enuf leverage to get the bolt on tight. I used a 3 foot pipe extension on mine (and I am not a small guy) just to give you an idea. Go with 4 foot if you can find some around. Just be careful cause with that much leverage the socket can't be allowed to slip or you will round off the bolt head something fierce.
Old Sep 30, 2003 | 06:32 PM
884runner's Avatar
the pulley
on the crank pulley there is a slot cut in to it like a deep groove, and on the shaft it has a piece that slides into the grove but on mine the piece that extends off the shaft that fits into the groove doesn't run down the whole length of the shaft so i don't know if it is even fitting into the groove on the pulley. is it supposed to or is it supposed to stop. If it's supposed to go all the way down the shaft then i think mine was filed off or something and that's why the pulley is unbolting hte bolt. Any ideas on this. Please help b/c i tired of driving my busted A$$ chevy around and i want my rig back. thanks
Old Oct 1, 2003 | 12:27 PM
szf2's Avatar
I wrestled with my HB bolt on my 3.0L forever trying everything I could think off. Couldn't use the high gear/ parking brake trick since I have an auto. Couldn't get a strap wrench tight enough around the crank pulleys and couldn't get anything wedged into the crank pulleys tight enough to keep them from turning. Almost made me want to retire my shade-tree-mechanic badge. I finally came up with the following tool which I made from some 2" flat and an old scrap pipe:
It basically bolts to the pulley using the bolt holes that are already there and keeps the crank from turning. If you don't have a tool like this and don't want to make one, I would go to a shop. It will save you a ton of hassle. Also, I removed the fan and radiator at while doing this (I was replacing the T-belt) and access was no problem. I would remove the fan at least. My $0.02.
Old Oct 1, 2003 | 12:31 PM
Cool idea. Man, that engine looks like it has seen better days!
Old Oct 1, 2003 | 03:22 PM
szf2's Avatar
LOL. My engine was having a bad picture day.
Old Oct 1, 2003 | 05:56 PM
884runner's Avatar
thanks alot
wow that tool is awesome. and thanks to everyone for their help. I think i finally got it tight enough b/c it's not comming out or loose and i just drove it (mildly) and all is well. i think the thread locking compound is helping alot. i'm just glad to be able to look down on other cars now instead of them towering over me. thanks all, alan
Old Oct 1, 2003 | 06:45 PM
DH6twinotter's Avatar
IMHO, the best thing to do is to make a tool like svf2 did. I made a tool very similar to his when I took that crank bolt off also. I just went to a local metal shop and bought a peice of 1/8"x4"x3' steal and drilled some holes in it. Works great and is a very handy tool to have around for later projects. You can use it to keep the harmonic balancer from rotating when you tighten the bolt. I placed the handle section under the frame rail and turned my rachet with a pipe on the end. (AutoZone has a free loan-a-tool program that you could get a torque wrench from to save a few bucks)
You should be able to tighten the bolt from underneath your truck. You will have to remove the skid plate first though.
Well, that's my thoughts on that.
Have fun all.
DH6twinotter
Old Oct 2, 2003 | 07:22 AM
TOR
Crank Pulley
If it does it again I would replace the pulley. I am a bit surprised you were able to get it back on with no difficulties. It sounds to me as though the pulley got damaged and is allowing the key way to pass up its groove. If it does it again this is what I would lean towards personally.
Todd
Old Oct 2, 2003 | 10:06 AM
If the key is moving then use a little RTV silicone to hold it in place.
Not recommended but a cheap fix indeed.
Bourbonblues
Dec 15, 2017 05:43 PM
Kylenicoll33
Sep 17, 2015 08:40 AM
Corvoid
Sep 14, 2015 10:10 AM
JHalcyonM
Sep 14, 2015 01:10 AM
anndel
Sep 10, 2015 08:50 AM
