Cpu upgrade?????????
Old Apr 28, 2004 | 11:16 AM
puka's Avatar
Sup fellas,
I was just wondering if there is ANY cpu upgrades out there that is worth buying!! Say for example "the Jet chip module" is this mod worth buying??
Old Apr 28, 2004 | 11:19 AM
rimpainter.com's Avatar
http://www.gadgetonline.com/fuel.htm...20Super%20AFC:
Scroll down to "ECU upgrade"
This wouldn't do anything for you. Dont waste you money.
Old Apr 28, 2004 | 01:36 PM
puka's Avatar
Wow thanks for the info Glad I didn't buy it yet that sucks!!
Old Apr 28, 2004 | 01:52 PM
PoBoy's Avatar
Hahaha! I read this when it was first posted a few hours ago and assumed it was in Off Topic. I thought you were talking about an actual personal computer. Glad I didnt reply to it. I was going to say CPUs are dirt cheap nowadays and so are motherboards. Swap it all out for a couple hundred bucks
Old Apr 28, 2004 | 03:06 PM
Fahrenheit 451's Avatar
I don't think the ECU upgrades really do much good unless you have seriously modified the engine. Then it would probably be a good idea to go with an ECU upgrade that was designed to match the mods.
Bigger pistons and taller cams require a different fuel curve and dinking around with the air flow meter to try and trick the ECU doesn't work very well in my experience.
kawazx636
Oct 6, 2021 03:03 PM
SpookyMulder
Nov 4, 2015 11:56 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
89YodaRunner
Sep 30, 2015 02:18 PM
4runnerFireman
Sep 29, 2015 06:24 AM
