View Poll Results: Brembos or Tundra Calipers?
Brembo rotors
15
40.54%
Upgrade and then Tundra calipers
22
59.46%
Voters: 37. You may not vote on this poll
Cost effective brakes?
Old Jan 17, 2007 | 11:27 PM
QSVeilside's Avatar
Weight reduction is always an option for us 2wd folks... I just removed 120 lbs of spare tire and skid plate stuff that I haven't used/dented/touched in 5 years. There is a significant difference in stopping ability as well as acceleration and MPG
You 4 wheelers can disregard this post.
Old Jan 18, 2007 | 03:15 AM
kevin444's Avatar
Get the tundra brakes night and day difference take advantage of a bigger rotor soo yeah.
Old Jan 18, 2007 | 08:06 AM
Midget96's Avatar
But the rotor isn't really bigger. It's marginally thicker. The caliper is mechanically the exact same thing. Unless you tow often, there is zero braking advantage to this setup. You don't increase the amount of braking torque, just the heat capacity of the rotor. Definitely not all it's cracked up to be...
I can see how everyone that puts Tundra brakes on their vehicle claims it's such a dramatic difference considering that most had barely functioning stock brakes to begin with...
Old Jan 18, 2007 | 08:12 AM
CJM's Avatar
CJM
I would say the cheapest route is to go with brembo blanks and better brakes. I use Hawk brand LTS pads on my T100 and they work much better than toyotas pads.
Old Jan 18, 2007 | 08:58 AM
  #25
gpcollen1's Avatar
I am glad you know that everyone had barely functioning brakes! Don't you think that many who UPGRADED actually know a bit about their vehicles ... and brakes? Many of us maintain the hell out of our vehicles!
You, on the other hand, have brakes that are adequate for your needs and riving style - good for you!
Old Jan 18, 2007 | 03:32 PM
  #26
CLEANSR5's Avatar
save money go with the brembo
Old Jan 18, 2007 | 05:10 PM
  #27
sharrack's Avatar
Even after a 4 wheel brake Job on my 99 runner with metallic pads.......I never liked the brakes and how the truck stops.
I always feel that if under the gun.............It might get ugly.
Afte driving mountain passes my brakes heat up and the start to pulsate.
After they cool down ...everything goes back to normal.
Kenny S>
Old Jan 19, 2007 | 06:21 PM
  #28
Midget96's Avatar
If I wanted to waste time showing you the numerous examples of people that had 120K on their stock brakes and then decided to jump on the Tundra brake bandwagon, I could certainly do it.
I know there's at least 2-3 threads that are 4 pages+ dealing with this topic. Go and read through them; you'll surely find that there are quite a few people that had marginal stock brakes and then decided to install the Tundra rotors and new calipers. Can't really make a fair comparison that way, can you?
Old Jan 19, 2007 | 06:31 PM
  #29
CJM's Avatar
CJM
The stock brakepads are just to hard a compound, good for people who just drive on the road casually-bad for spiritied and offroad drivers.
My camry had the same pads and stock rotors, the rotors warped after a wheel bearing went and I couldnt afford to fix it asap. Turned the rotors and instaleld performance pads and voila it stopped better than before I had warped rotors.
All you need is better rotors and pads, I upgraded to brembo rotors and hawk LTS pads for my T100 and it stops on a dime.
Eggslinger
Jun 8, 2019 03:32 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Flossy
Aug 5, 2015 05:14 PM
CanRunner
Jul 20, 2015 01:29 PM
