confused about engaging 4x4
See that gets me...
I beleive it is still 2WD until the button is pressed, then it becomes AWD and then when the center diff is locked it becomes 4WD...
The reason I say this is cause the first time I got in it...
(Stepdad was on business mind you...)
I did a burnout, out of the drive way...
It was rear wheel all the way so...
I believe it is sitll a true 2WD, just toyota put a little more inovation into the t-case so you can have teh AWD feature for light snow and heavy rain, and then the 4WD (once center diff is locked) feature for som more heavy duty snow and off-raoding...
Someone correct me on this if I am wrong, but that was always my impression
It's 2WD to boot
Then the button on it is AWD
Then the center diff locke is 4WD
right?
It's 2WD to boot
right?
How will using 4-Hi make me a better driver? I only use 4-HI on dirt roads. Anything other than I use 4-LO. I thought about it and can't figure out why 4-hi will make me a better driver. I've been wheeling for a 5 years now, and I have had no problems with not using 4-hi other than dirt roads.
How exactly does drivin in 4Hi make anyone a better drive?
Like in what sense?
Just curious, cause thats all I have wheeled in except that one time and I didn't think I was that great compare to all of you here on the site...
To my friends on the other hand I seem to be a pro...
Just curious...
#25
I have used 4lo once, and it seemed so pointless.... High RPM/low speed
but i do need to take into acount what i was going over required speed (big sand dune) because traction would required deflating tires which i didn't want to do....
Still not a big wheeler (until i get rid of the highway terrains), but im also curious for the future, should 4low or 4high be used more often.
#26
i was referring to picking better lines and such. not bashing using 4lo. i think it made me a better driver not using 4lo unless i needed it. lets say, climbing a 35 degree hill 35 feet with rocks all in the way. if it wasnt muddy out, i wouldnt use 4lo to force myself to pick GOOD lines in 4hi that way i wouldnt need lo. if i was in lo, wouldnt really matter what lines i took. as long as the rocks wouldnt get hung up on the axles, you would just barrel your way up. for that matter, i dont use the locker in the same respect either. i know it has my back so i try not to use it. make since?
guess its just me
guess its just me
#27
guess its just me
guess its just me
I always frind that I am trying to find the best way through and obstacle then hitting it head on...
Granted I also do that if I know the obsticle I am going to hit is going to throw off my alignmnet...
(would like to keep the good until I get a little more money to be able to go to get an alignment after every wheelin trip)
But still I see your point...
And abou tthe e-locker...
I don't even have one, so I def have to calcuate how I am hitting and obsticle...
#28
See if your local Firestone has the lifetime alignment deal. I paid $160 bucks one time and I have lifetime alignments as often as I like as long as I own the vehicle. I did this after I lifted it as well...
#30
I guess the twist this thread has taken at this point is more about 4x4 riding style.
In my case I use 4Lo in the hills to provide more torque, thread through tight squeezes and it generally smooths out rocky inclines. Others like to use speed and momentum (4Hi) to blast through trail sections, sometimes this is a needed approach, other times it's just bronco-rough and promotes wear-n-tear.
My whole philosophy is to minimize ware-n-tear on my truck, this approach keeps me from dumping money into my ride because of damaged parts and blown shocks; 4Lo provides that alternative.
Bottom line is that each section of trail needs to be assessed and considered on a case by case basis, sometimes 4Hi, sometimes 4Lo.
If you live in the flatlands I can completely understand not needing 4Lo. In those places most often there are no obstacles to necessitate it.
YotaFun let us know how your 4x4 trip goes and your opinion on this matter once you give it a shot.
-Youngster
-Youngster
#31
if you have the push button style shifter, with the selector in hi, and the 4wd button pushed in, you are in essentially an awd mode. when the center diff lock is engaged, you are now in a true 4wd, kinda( without front and rear diff lockers, you can only garuntee that 2 wheels will be getting power).
as for using 4hi or 4lo.
4lo= lower gearing= more torque= higher engine speeds= lower wheel speed.
this is used when rock climbing, going over large obsticals, or some hill climbs.
4hi = 4wd with no change in gearing from 2wd. this will mean that more strain is put on the motor, because you are now driving two axles instead of one, although the difference is slight.
different types of terrain will require different driving styles. in the rocks, speed is an enemy. it will usually yeld you bady damage or broken drive train.
in the mud, you need lots of wheel speed to clean the mud out of the lugs of the tires so that they are better able to provide traction on the next revolution.
#32
Ive got an 02 sport with the button on the shifter. When i push it the indicator shows 4 green lights. There is a button on the dash that i can push and a flashing orange light shows (Trans. Case?)... confused now. That is the one thing that i liked about my jeep. When i put it in 4WD it was in 4WD. What are the different modes for the 02 sport auto? Thanks
#34
#36
That is the only difference between me and you i believe.
The 02 (and 01 i think) would have an AWD option - read through the thread for that
#38
-Youngster
-Youngster
(will be posting a thread later...)
You have a center Diff that locks to make your AWD into 4WD
(I think this is stated somwhere ealier in the thread)
No Dumb question here on yotatech, When you new to the world of 4X4's and a yota in general question you will have....
I don't know the complete diffrence if any ther is between having the tranny in neutral or having the T-case in neutral...
All I noticed is when I have the t-case in nutral the car is easier to push if i need to get it out of the way While I am working on it (mom usually needs to get out of the driveway and I am in the way...)
Or it could just bethere as a feature to prepare the t-case for 4 low..
I have been reviewing a couple of 4WD systems in alot of diffrent suvs and trucks (me and stepdad are the only one that have yotas, all our friends have somehting diffrent) and noticed that almost all hae a Neutral option...
The only one that I hvae come across that does not have a nutral option are All-Time-All-Wheel-Drive or the new 4Gen 4Runners with the V8 that only have teh 4Hi and 4Lo option...
just my .02 on that issue
#39
"J" Pattern... multi-mode transfer case
With the shifter in the normal postion you are in 2wd. If you press the button, shifter doesnt move, you are in AWD.. and depending on your year you may or may not have VSC.. AWD is fantastic.. can be used anytime with no damage to drivetrain, and only slightly to mpg. It used a torsen center differential that typically splits power 40/60. F/R.. My 03 has the same setup, just different shifter.. I LOVE IT.. it makes snow/ice/dirt/rain so much better to drive in... Now when you pull the shifter straight back you lock the center diff and are now in 4WD.. the when you push the shifter to the right N, the R and FWD to 4LO.. same as 4HI, just lower gearing... 4LO is used at slower speeds for more control, and the feeling of more power... Use it.. your tranny and brakes will thank you...
the aft-fore multi-mode (01-02) center diff lock in on the dash.. courtsey of Yotafun
Originally Posted by yotafun
The position it is in for normal drive is all the way back
When you press the button AWD is engaged and the 4 Tires on the Dash Light up...
When you hit the button on the dash for the locker the center diff locks and a oragne light comes on solid to show that the center diff is locked...
Then you shift into neutral and push the stick all the way foward for 4Lo
The other shifter is 2WD in the fwd position, press the button you are in 4WD, then pull back for 4LO...
The mult-mode is much much better than the 4wd you had in your jeep... and when you put your runner in 4wd, its 4wd just the same... But you now have the AWD or fulltime 4WD option.. which allows you to power all 4 wheels, but wont cause damage on dry roads, or make it hard to turn...
As far as your dash lights, IIRC in 2wd nothing is lit.. then press the button.. all four tires go green.. AWD.. pull the shifter back for 4wd.. the center orange indicatior will blink, when its solid you are in 4wd..
#40
There are 2 transfer case shifters that have buttons. One that moves in the "J" pattern, and one that only moves fore-aft... Here is the difference
Wow thats intresting, learn something new everyday...
I didn't know there was a "J" style shift witht he button that worked like that...
I wish I had that...
