Compresion in a 22re
Old Jan 31, 2005 | 05:41 PM
bike4miles's Avatar
Compresion for a 22re
I was wondering what is the ideal compresion range for a 22re? Mine is about 75 to 70psi, is that good?
Old Jan 31, 2005 | 05:57 PM
waskillywabbit's Avatar
Uh, I thought good was 160+...my 85 22RE tested at 165+ all 4 cylinders....sounds like yours is going kaput...
Old Jan 31, 2005 | 06:18 PM
bike4miles's Avatar
O wait, I thik it was 175 to 170. It was a while ago. So in that case mine is good then?
Old Jan 31, 2005 | 06:21 PM
Yamaha+Toyota=Fun's Avatar
70=bad
170=good
I recently tested the compression on my truck and I had about 175-180 across the board.
Old Feb 1, 2005 | 07:02 PM
alanbobalan's Avatar
what kind of shops do compression tests? just curious...
Old Feb 1, 2005 | 08:57 PM
bike4miles's Avatar
You can just buy a cheep gauge and do it your self for about $40 less. That's what I did. Takes 2 people though.
Old Feb 1, 2005 | 09:08 PM
SoCal4Running's Avatar
You can do a compression test by yourself.
Just remove all the spark plugs and thread the compression tester into one cyliner. I usually set it on the motor so I can see the dial because the first crank psi is just as important as your final crank psi. Hold the throttle WFO and crank the motor at least 4 revolutions making sure to see what the first crank reading was.
Jayboy74
10
Dec 21, 2021 08:27 AM
JNapolitano
Nov 14, 2019 07:46 PM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
