Cold Tranny Issues--99Runner
Old Mar 20, 2008 | 07:52 PM
wjwerdna's Avatar
maybe drain the pan, just to see how fluid looks?? cant hurt? 2-3 quarts
Old Mar 21, 2008 | 04:06 AM
mt_goat's Avatar
Originally Posted by Holla
If it means droping the valve body I dont know..lol
You don't need to drop the VB, just the ATF filter. It would be a good idea to check the filter anyway.
Old Mar 22, 2008 | 12:03 PM
mt_goat's Avatar
Originally Posted by www.Off-Road.com
The A340E/A340F/A340H 4-Speed Automatic Overdrive Transmission
This is Toyotas ECT (Electronically Controlled Transmission) automatic. It is used in both 22RE (4wd) models and in the 3VZ-E and 22R-TE (both 2wd and 4wd)
1st 2.804, 2nd 1.531, 3rd 1.000, 4th 0.705 Reverse: 2.393.
The 4WD version (A340H) has a transfer case with low-range gearing of 2.659:1
Models designated A340F have (I think) the VF2A transfer case with a 2.566:1 low range
Someone who asked to be anonymous sent the following info:
The codes breakdown is as follows
A 340 H
A = automatic transmission
3 = 3 series
4 = 4 speed
0 = gear ratio / minor change
H = hydraulic transfer case (includes ECT)
F = mechanical transfer case (includes ECT)
E = Electronic Controlled Transmission (used on 2WD 4Runners, other 2WD Toyota vehicles)
This transmission uses 2 solenoids to control the shifting.
solenoid 1 solenoid 2
1 th = ON OFF
2 nd = ON ON
3 rd = OFF ON
4 th = OFF OFF
The throttle cable is used for line pressure, it can be disconnected and
the transmission will still shift normally.
But if you loose power to your 2 shift solenoid, you will be taking off in
OverDrive.
Old Mar 22, 2008 | 01:38 PM
Erich_870's Avatar
Great info Goat, thanks!
Erich
Old Mar 22, 2008 | 04:46 PM
  #25
Holla's Avatar
Yes thanks--the toyota guy also stated that maybe a Cable could be out of adjustment and may be causing it?? Is that a possibility?
Hmm so a 50/50 shot of what solenoid is bad.
Old Apr 7, 2008 | 03:23 PM
  #26
brandyn85's Avatar
hey guys i have the same problem with my 99 limited runner... except i get a check engine light when it gets real bad... my fluid and filter have maybe 2k miles to work and back since the last change so i know its still good. mines to the point now to where i have to put it in LOW everytime i come to a stop. had the cell pulled and it was "shift solenoid A electrical"... the guy who i talked to said that one or both of my solenoids are about to take a crap... so i went today and picked up a set of both solenoids today for $130... cheaper to buy 2 in a package than a single one for $109... im just going to replace them both...
Old Apr 8, 2008 | 10:43 AM
  #27
Erich_870's Avatar
What is the part number for the pack of 2?
Erich
Old Apr 13, 2008 | 07:23 AM
  #28
brandyn85's Avatar
i'll run out to the shop and see if the box is still laying around after i get off work today. i replaced them yesterday and it shifts great now, it actually upshifts normal now too... i didnt notice how it wasnt shifting right until i replaced them.
Old Apr 14, 2008 | 09:07 PM
  #29
brandyn85's Avatar
its a PTW part the store said so i dont know what that means or where they ordered it from, but the part number is PTW52-0230. it comes with a few different mounting brackets for a few different trannies. if i remember right i believe it shows for 3 different toyota transmissions. but the runner is back to shifting normal! dont have to look like an idiot anymore shifting the automatic. i hope this helps you guys
Old Apr 23, 2008 | 03:48 PM
  #30
Erich_870's Avatar
That's great to hear! I'll have to add this to my list of things to do.
Erich
viesail
Sep 21, 2015 06:00 AM
tallsasquatch
Sep 20, 2015 02:48 PM
eggens
Sep 5, 2015 12:16 AM
moparbay
Sep 3, 2015 12:48 PM
