Coiled brake line
Coiled brake line
A brake line that's below the master cylinder that looks like a spring. Anyone know this? I can't find the part anywhere and I believe I have a leak from it.
That turn of 2-3 coils of hardline brake line is to absorb vibrations between the master cylinder mounted to the body and the T-union bolted to the frame. To replace it just buy standard line and coil it around a pop can to recreate the twist.
If you have a standard shift there is a similar coil along the passenger side for the clutch line.
When you bend line, slow and gentle is the way to go. You don't want to crimp the line and limit fluid flow internally.
Go on amazon search Nichol Cooper brake line, 3/16”. Flares are M10x1.00, use stainless steel. DO NOT GET ALUMINUM. NiCu is stupid easy to make lines with. Can burrow a flaring tool from Autozone.
