clutch question
Old Apr 10, 2003 | 02:03 PM
injektilo's Avatar
Question clutch question
What's up guys? I've started to notice that on rough roads I can hear my clutch pedal bouncing up and down a little bit. I assume that most clutches have a little play in them but should I hear it bounce? I usually hear it as I'm slowing down. How much play should a clutch have. Is there an easy adjustment I can make to the clutch or is this typical? My truck has a little over 38k.
Kevin
Old Apr 10, 2003 | 02:26 PM
rimpainter.com's Avatar
You mean rattling? Or literally bouncing?
There is some side to side play, that is normal. And about 1/2" of in/out play. After that, you have problems.
Old Apr 10, 2003 | 02:38 PM
injektilo's Avatar
Maybe bounce was too strong a word. I can definately hear it move when I go over certain bumps. I'm pretty sure it's the side to side play. The other day as I was pulling into my apartment I could hear it so I glanced down and it looked like it was bouncing side to side. Kinda' hard to tell though.
Kevin
Old Apr 11, 2003 | 06:07 AM
It sounds like you have more of an annoyance than anything. The problem you describe shouldnt be a drivebility issue. If it bothers you, stick your head under there and take a peak at the components. Looks for anything out of the ordinary. If it would make you feel better, you could stop by the dealer and grab a tech for a sec, and see what he thinks. Remember, they cant charge you unless you sign.
Old Apr 11, 2003 | 08:39 AM
injektilo's Avatar
Thanks for the advice. I appreciate it.
Kevin
the1998sr5
15
Jul 14, 2020 08:35 PM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
upongame619
Aug 1, 2015 12:12 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
1996Taco
Jul 20, 2015 12:02 AM
