clunk and bang turning left
Old Mar 5, 2004 | 08:09 PM
MarknSher's Avatar
We have a '92 Toyota SR5 4x4 pickup with V6 engine - stock.
Sometimes, when turning left (can't make it do it when turning right) there is a clunk and a bang which seems to come from the rear - seems to hit right in the seat of the pants.
It feels like I just drove off a curb suddenly.
Any ideas what this may be.
I have a separate, perplexing problem I will ask about in an different thread.
Thanks a lot for any insight.
Mark and Sher
Old Mar 5, 2004 | 08:16 PM
Mossback74's Avatar
We think its a broken/ damaged anti-swaybar bracket. While both of you are under there check the front axles/CV Boots. You two may want to take the wheel off, check the brake caliper and make sure you get the lugs tightend when reassembling (80 ft/lbs I think). Uhhh that's all we got, Welcome to the board, all of you
Old Mar 5, 2004 | 08:22 PM
MarknSher's Avatar
Hmmm... this may correspond with the "new" rattling sound of the suspension.
Thank you SO much for your reply.
Thanks for welcoming us.
Old Mar 5, 2004 | 08:25 PM
AgRunner06's Avatar
This is just a shot in the dark, but it could be a broken leaf spring.
Old Mar 5, 2004 | 11:07 PM
Mossback74's Avatar
All my money is now on sway bar. For new bushing (and bumpstop) info read through THIS THREAD . Pay attention to 2nd gen part numbers. It's really easy to do. Two bolts on each side.
Old Mar 8, 2004 | 11:29 AM
MarknSher's Avatar
Clunk & Bang - Still there
We inspected all suspension components and drive train - nothing broken, nothing missing - nothing bent. U-Joints feel tight.
Checked the front axles and CV joints (tugged on them) and they feel reasonably tight - slightly rattley - but no more than for the last 4 years.
They don't bind in a turn or in reverse turns.
We also drained the gear oil from the rear end - as it appears it may be coming from that area - although hard to tell for sure.
There was nothing in the oil - or on the magnetic drain plug, other than wear and tear residue (dark grey powder - very little)
It handles normally.
It only happens under load, turning left - turn left, straighten out, press throttle and clunk bang.. kinda feel it in seat of pants.
It does not happen all the time - 1 out of 5 turns maybe.
Had two people sit in bed of truck and they say it sounds like it's coming from the rear area.
Very odd.
Old Mar 8, 2004 | 11:38 AM
Robinhood150's Avatar
Did you get this new or used? It almost sounds like you have a locker in the rear.
Old Mar 8, 2004 | 11:54 AM
MarknSher's Avatar
Locker in Rear?
How would I tell? - I did buy it used - and I really don't know.
Thanks for the idea... If I do... what does this mean, as far the noise goes?
Mark
Old Mar 8, 2004 | 06:25 PM
Mossback74's Avatar
How would I tell?
Block the front wheels, put it in neutral, jack up one rear tire and try to turn it. If you can, you have open diffs.
Old Mar 8, 2004 | 07:08 PM
Tacoma Dude's Avatar
Steve:
But wouldn't they hear the same thing taking right turns too?
jasonty
41
Dec 23, 2018 01:00 PM
stock87yota
Jul 31, 2015 10:08 AM
ripp96
Jul 25, 2015 02:32 PM
Hamonacracker
Jul 17, 2015 08:33 AM
hamburg99
Jul 13, 2015 09:54 PM
