click click boom?
Old Aug 27, 2004 | 05:33 AM
krem8tr's Avatar
click click boom?
here's my problem 1991 4Runner 4x4........i just replaced driveshaft and no more shimmy shake....however whenever i'm in 2wd i get a click from under the drivers side of the dash.....kind of a relay open/closed click......it's especially noticeable when i hit a few bumps.....here's the kicker.....it clicks louder and faster and then i get a sound like the drive locked up or snapped....and just as fast as it happened...it's gone.....back to the clicks...if i put it in 4wd.....no clicks but that another story.....as long as i keep my speed above 10mph no worries.....less than 10mph...i think the front driveshaft locks up........is there anything under the drivers side dash that would control the driveshaft or more than likely the transmission?....please help me!!!
Old Aug 27, 2004 | 06:14 AM
WolfpackTLC's Avatar
Hmmm..... You're in Durham... you sure it wasn't a drive by you were hearing?
Seriously... I have no idea... but I'd wager to say that I doubt that anything electrical is contributing to your issues. It sounds like you may have improperly installed the drive shaft... perhaps you lined up the splines wrong and you were getting a vibration? Check that first! The yokes on the d-shaft should be pefectly lined up when on a flat surface. Even a deviance of 1 spline will give you a vibration. It sounds like you may have grenaded a u-joint, to be perfectly honest.
Old Aug 27, 2004 | 06:47 AM
krem8tr's Avatar
Durham only has drive bys on Thursdays and every other saturday......lol.....if i had screwed up the ujoints wouldn't it make the same noise in 4wd?......
Old Aug 27, 2004 | 07:10 AM
Buki's Avatar
I don't know if this helps, but when I had a clicking under the dash on my 88 it was because of the speedometer cable. It had to be taken out and regreased.
Old Aug 27, 2004 | 07:03 PM
MAYBE the speedo cable, IF it wasn't also upsetting the driveline itself...
Old Aug 29, 2004 | 05:18 AM
10cents's Avatar
Maybe it was hit by a stray bullet. I lived in Durham for 2 months and there where 7 drive-bys in a 3 block radius.
Old Aug 30, 2004 | 06:05 AM
krem8tr's Avatar
OK OK enough about Durham.....it's not that bad where I live...(in the sticks) anyway found out that the A.D.D. relay was crapping out......$64 bucks from the stealer.....4 day waiting time
Davebarbier
Nov 3, 2015 03:28 PM
pickle6415
Oct 19, 2015 08:08 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
PureTacoma_Tundra
PureTacoma_Tundra
Sep 24, 2015 12:14 PM
