Chevota Emissions Help
Old Apr 29, 2003 | 07:17 AM
Denk's Avatar
So I got an '89 Toy P/U with an '85 4.3 L Chevy V6 and a quadrajet carb....not passing emissions. Does anyone have any thoughts on how to lower emissions a few %?
Old Apr 29, 2003 | 07:19 AM
rimpainter.com's Avatar
Which emission are you failing for?
Old Apr 29, 2003 | 07:31 AM
Denk's Avatar
My bad...Washington.
Old Apr 29, 2003 | 07:49 AM
No, what type of emission? NO, CO, etc.
Old Apr 29, 2003 | 08:03 AM
Denk's Avatar
regular tailpipe emissions, carbon monoxide, etc...
Old Apr 29, 2003 | 09:25 AM
Ok, on your emissions print out, they break down the % and the types of emissions...
that's what we need to know.
For example:
NO: 2.25PPM
Old Apr 29, 2003 | 09:47 AM
Denk's Avatar
Seeing as how I do not have that print out, are there general tips/tricks for reducing emissions. The carb has already been tweeked. Not sure what else would help. redline fuel system cleaner, maf sensor clean...? Is there a way to test to see if cat is blown without removing it? Probably not, but thought I would ask.
Old Apr 29, 2003 | 09:53 AM
Tweeking the carb could be part of the problem. You may want to have the O2 sensor tested also. Running rich can contribute to failed emissions, and possibly a failed cat over time.
What type of cat do you have on there? Is it the original cat from Toyota, or did you use one from Chev?
You can try a product that will clean the combustion chamber, but that probably wont get to the root cause of the problem. Are you pretty handy with motors? If not, then you may have to have this problem diagnosed by a professional. There are just too many variables, and the last thing we want to do is send you on a wild goose chase.
Old Apr 29, 2003 | 10:09 AM
Denk's Avatar
The cat is original toyota, and I am good with working on ford engines and partial toyota, so this chevy shouldn't be a prob. I guess its just gonna have to be trial and error time. The only other thing I can think of is to overhaul the valves and piston chambers. Thats easy enough. I love old engines that you only need to take out a few bolts and springs and the thing almost just falls apart. Thanks for the insight...
Old Apr 29, 2003 | 10:11 AM
Keep us posted.
Old Apr 29, 2003 | 05:02 PM
Yoda's Avatar
Well, in Washington you could fail on:
HC this is hydrocarbons=unburned fuel
CO This is carbonmonoxide
CO2 carbonDioxide=text for nonleaking exhast
Is it a stock 4.3? out of what (and the year)
What is the carb from?
Camshaft stock to engine or aftermarket
Emmissions stuff hooked up to the 4.3? O2 sensor installed and working with a GM computer?
Old Apr 29, 2003 | 05:07 PM
HaveBlue's Avatar
You might check your PCV valve, too. My Honda failed a couple years ago just because of that $2.00 part!
kawazx636
Oct 6, 2021 03:03 PM
dbollier123
Sep 29, 2015 05:23 PM
Keithstoyota
Sep 27, 2015 07:29 AM
Boomer8404
Sep 24, 2015 01:12 PM
