Check THIS out.
Finger
Yep, I do. The Taco diffs use 17mm bearing bracket bolts, and the actual bearing cap is one piece, without the carrier bearing preload mechanism that Runner/pre-Taco trucks have (Tacos use shims). The studs for the third are also 10mm with 14mm bolts (Runner/pre-Taco uses 8mm studs I believe), and the pinion is different as well. And I believe you are right about the spider gears as well, I think the Taco's are 30 spline as opposed to 27 spline for Runner/pre-Taco.
its a 4banger, but it is an 8" and the arb locker i have came out of a v6 4runner (3rd gen).
#26
I would, but its a little too much trouble since I am 1200 miles away from the part. If i was at home i would take some pics. I'll see if my dad can take some pics when he stops by my place this weekend.
rushw
Jul 18, 2015 01:46 PM
That's cool. Thanks for the help!
