Check THIS out.
Old Mar 17, 2008 | 03:49 PM
FingerMan20's Avatar
Originally Posted by crolison
I have a the whole set up carrier (no ring and pinion) for an 8" diff.
Came out of a 97 runner with 95k miles on it, replaced with an arb.
the only problem is that i am in TX and its in TN
but i think you have the 8.4" r&p
97 V6 Runners (I think only the V6 models) had 8" 4-pinion spiders, and the Tacomas from '95.5-'00 had 8", 2-pinion spiders. The 8.4" came in later year Tacos. Is your Runner a 4-cyl? If so, I think it might be the same diff.
Finger
Old Mar 17, 2008 | 03:58 PM
wjwerdna's Avatar
Originally Posted by FingerMan20
Yep, I do. The Taco diffs use 17mm bearing bracket bolts, and the actual bearing cap is one piece, without the carrier bearing preload mechanism that Runner/pre-Taco trucks have (Tacos use shims). The studs for the third are also 10mm with 14mm bolts (Runner/pre-Taco uses 8mm studs I believe), and the pinion is different as well. And I believe you are right about the spider gears as well, I think the Taco's are 30 spline as opposed to 27 spline for Runner/pre-Taco.
NICE! sounds like someone has been doing their homework, wish more people would do the same
Old Mar 17, 2008 | 06:10 PM
Someone's gotta do it! But everyone on this board knows so much about their specific truck... it's unbelievable! Total dedication.
FingerMan
Old Mar 17, 2008 | 06:24 PM
crolison's Avatar
Finger
its a 4banger, but it is an 8" and the arb locker i have came out of a v6 4runner (3rd gen).
Old Mar 18, 2008 | 04:51 PM
  #25
Is it a 4-pinion designed diff? I think it is, but I'm not sure...
Could you post up a pic of the carrier body (If it's not too much trouble)?
Finger
Old Mar 18, 2008 | 05:18 PM
  #26
crolison's Avatar
Finger
I would, but its a little too much trouble since I am 1200 miles away from the part. If i was at home i would take some pics. I'll see if my dad can take some pics when he stops by my place this weekend.
Old Mar 18, 2008 | 07:32 PM
  #27
LOL... *foot in mouth* That's cool. Thanks for the help!
BTW, your avatar looks like a time you might have taken your Runner for a swim? Awesome.
Finger
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
young buck
18
Aug 27, 2018 02:40 PM
rushw
Jul 18, 2015 01:46 PM
ryerye13
Jul 14, 2015 08:27 AM
