Chasing a Rattle
Old Mar 25, 2007 | 03:10 PM
Midnight Runner's Avatar
Chasing a Rattle
I just picked up a 96 4runner LTD. It didn't do anything on the test drive and seemed perfectly fine.
I bring it back and now once the truck is warmed up, there's a rattle. When in the cabin, the rattle comes from the rear around the cargo area. Then I went to investigate outside the cabin and followed it to the front engine area.
I'm thinking something got loose over time, and is now really close to something that heats up and expands.
This only happens when the truck is in drive.
Does anyone know what this could be?
Old Mar 25, 2007 | 04:16 PM
seanz0rz's Avatar
Guest
id start by checking the exhaust system from front to back. make sure no heat shields are rattling, in contact with anything, etc. etc.
what kind of rattle? plastic rattle, metal rattle? that would help us alot.
Old Mar 25, 2007 | 10:44 PM
Rattling definitely sounds larger in size. It very well could be the exhaust. It sounds like it's metal on metal, but it's not raspy. It's more thudy...
Old Mar 25, 2007 | 10:57 PM
seanz0rz's Avatar
Guest
check motor mounts.
Old Apr 4, 2007 | 10:56 PM
Originally Posted by seanz0rz
check motor mounts.
Hmm ok, I know on a camry, you just hold the car with the brake, give some gas and watch the motor. I'm not sure what to look for though.
Old Apr 4, 2007 | 11:59 PM
seanz0rz's Avatar
Guest
well just find them and inspect them for cracked rubber, etc
Old Apr 5, 2007 | 01:48 AM
KU_MechE's Avatar
im almost positive it's your exhaust. I had the same problem, but mine rattled at exactly 1500 rpm. It was determined to be a loose exhaust shield. It would only rattle in drive b/c of the increased load on the exhaust. good luck
ashamsuddin
17
Jul 22, 2024 03:59 AM
gibbonsballer10
Oct 26, 2023 07:13 AM
zytra
Jan 24, 2019 03:16 PM
live4soccer7
May 11, 2016 06:52 PM
Flightguy
Oct 2, 2015 05:34 PM
