Charging system alternator question
On my '00 Runner I have noticed that at idle with heater on, rear defroster on, wipers on, etc, the battery voltage will drop from 13.6 down to 12 volts (sometimes even lower). If I engage the A/C, the rpms usually rise enough to boost the dropping volatge. I replaced the OEM battery and much the same symptoms other than before it would drop down to low 11's.
If I bring engine speed up by a couple of hundred rpm over idle, say to 850 - 900 rpm, the altenator brings the voltage right up to more than 13.5 volts. Do you think that my alternator is on its way out? The engine is a 3.4L V6. Never any other propblems like starting etc. even in real cold weather.
I searched the net for remanufactured units. Anyone have any experience with eBay remans? Found voltage regulators but they are more expensive than a remanufactured alternator!
I think the stocker is an 80 amp unit. I am basically stock on electrical load. Any opinions on going to an upgraded reman to say 120 to 130 amps?
Thanks
Thanks
Don't replace the alternator, just put in new brushes
http://www.4x4wire.com/toyota/mainte...nator_brushes/
Aftermarket are junkl. Nothing better than the stock denso alternator.
Thats only about a volt and a half drop. Not bad for running all those accesorries at idle. I really wouldnt worry about it. Your car isnt made to sit at an idle with everything on anyways. I think your charging sys is working fine. Your battery will go before your alt will. When your alt does stop charging, get a set of brushes for it. Or if you are that worried, buy a denso reman
Alternators optimal output is around the 2000rpm range.At Idle it really doesnt charge. Your system seems fine, just make sure you have a good battery, because a bad one WILL take out your alternator.
Thanks
Thanks
Your system is working normally.
Thanks everyone for your input! I will order a set of brushes and pop the alternator out and check the old brushes out once the weather warms up (hopefully in a month or so). That's the problem with digital gauges, sometimes they make you worry for nothing.
Vic
Vic
If you have a set that will fit an '00 with a 3.4L and Denso alternator, I would be interested in a set. Pricing less than the stealer would be good. Haven't had a chance to look into it yet and may not do so until the warm weather arrives.
dang and that will save atleast a 100 bucks too.. can anyone really verify that this is worth the effort? meaning that it wont go bad pre maturaly bc the rest of the alt is older than the part being replaced.. hope that made sense
Yes, the brushes usually wear out first, but there's no guarantee on the rest (bearings, regulator, etc).
Alternators are more in the "if it ain't broke, don't fix it" category......if you'r charging at 14+ volts at 2500 RPM, leave it alone!
understood.. but its nice to know your options when it comes time to replace the whole thing or just the brushes
i agreed with you to begin with jamie. i normally wait till its shot before replacing. i just had no idea it can be fixed for 30$ or less
ok. sorry I havent gotten back to you sooner. I called the stealer and they wanted $23 for the brushes and they had to order them. DUMB. I will sell you a set of alt brushes, delivered to you for $20
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Avenged
Jul 9, 2015 07:55 AM
