Last edit by: IB Advertising
- Toyota Tacoma How to Replace Oxygen O2 Sensors<br>Step by step intructions for do-it-yourself repairs.
Changing Oxygen Sensor when nuts are rusted
they will die between 100,000 and 150,000 miles almost guaranteed.
it is the ceramic element which just loses enough molecules so it won't
function, or it gets clogged
or the heater circuit dies.
but you only need to replace them when they blow a code
you may improve mileage 1-3% or so if you replace them
before they blow a code (the front one)
Reading these comments, it seems to me that the front sensor controls fuel mixture and the downstream sensor checks on the performance of the cat converter. This sound about right?
We got the dreaded check engine light so I ran my scanner on the 4Runner that the downstream sensor was out of range. Got a price from the stealership of about $364 for the sensor and another 3 hours ($357) to perform the extensive work involved in the changeout. NAPA Grand Forks helped us out for $110.09 and some 15 minutes of my time got the job done....thanks to the great info above I had no fear of jumping on this problem. I'm $600 ahead of the game just for hanging with you guys. Beers are on me!
Joe
Joe
#25
Joe
Joe
A dealership parts counter only charges 211 for the a/f up front
and 150 for the o2 out back.
holy crap I am in the wrong business
#26
Maybe they were adding in replacing the bungs because the studs were rusted in and too bad to reuse. And of course since Toyota doesn't sell the bungs individually they have to replace the whole section of exhaust.
#27
BS? Oh, I wish!
The bigger problem is that we are running 2 Toyotas, a 4Runner and a Rav4.
Another short story to expand the point - the 4Runner turned out to have bad front struts....actually they're coils over shocks but I guess that struts sound more scientific and more worth the money. Anyway, these cost $437.40 with $291.76 for labor. Picked up a pair for $93 each and will replace both front shocks this weekend. With the help of the wise folk here, I will henceforth avoid the stealership $119 per hour labor rate.
I will save the $700 gas filler and the $650 driveshaft tales for a cold rainy night story.
I think I've got the process straight, but are there any hints on changing out the shocks?
Joe
Joe
#28
Got the front shocks changed out this morning in 2 1/2 hours. New units cost me $94.19 each and I avoided $437.40 & $291.76 labor for each of them. I'm $1,200 ahead today The great part of high Stealership pricing is the amount of money I save doing it myself. I'm now looking forward to the next problem so I can keep adding up my savings you guys keep helping me collect.
Many thanks and beers on me when we link up!
Joe
Joe
#29
You might get lucky and char the nylon insert to the
point the residue loads the stud threads.
A better approach would be either a deformed locknut
or a serrated-bottom flange locknut. Also IIRC aluminum
based anti-seize isn't recommended for exhaust use
but rather requires the copper based compound.
#30
#31
#32
You don't get it. Leave the anti-seize off and corrosion sets in the first winter and locks it better than any stinkin' lockwasher or lock nuts. Then, when it's time to change, just squeeze those nuts with your pliers and they crumble right off. Piece of cake. Why do you think the factory avoids any use of anti-sieze? Get with the modern application of Japanese fastener technology. It called Fastener Regulation Assisted by Corrosion--FRAC.
#33
Hi, I have a 2000 4Runner with a PO136 code. I changed the forward O2 sensor no problem. Same code came back. I tried changing the rear one.
However there are no bolts there that look anything like a bolt just a lot of rust. I am hesistant to start chipping away at whats left of the bolts for fear of damaging the threads. Any help would be appreciated, I really don't want to take this to a dealer.
#34
Can you take a pic of what you're talking about?
Fink
#35
#38
New to this site. Pic is way over site limit of 48K.
How do I post a pic of normal 1 Mbyte size?
Ok Got it now
Well after about another 4 hours of squirting PB blaster, NAval jelly and a
lot of pounding I finally got the so called bolts off. I actually wound up using a wood chisel too pound at the bottom of the nut where I did not see any threads showing thru and chipped away at the rusted nut. It finally broke free and I was able to pry it off. I bought new stainless nuts and washers at Lowes this morning. Now all I need to do is order the new O2 sensor. Bset price I see is at Amazon. Denso 234-4153 for $62 . I hope they solves my issues. Will post when I know.
#39
Joe
Joe
#40
I had a different occurrence with my O2 sensors. One nut, the thread ripped off, had to slide the stripped nut off, then get a die set to clean the threads. The other nut stayed rusted on, and the whole stud came out of the exhaust peice. I couldn't get the hut off without damaging the threads, so I just put a grade 10 bolt instead of the stud.
