Changing out headlights??
Old Sep 29, 2003 | 08:33 PM
Brad's Avatar
Question Changing out headlights??
Probably a dumb question and I'll probably figure it out later than sooner but I thought I would run it by everyone hoping for some leads. I bought new headlights on ebay and after looking at the ones that are in I can't seem to figure out an easy way to change out the casing and all!! Has anyone done this that can offer any tips?
:pat:
Old Sep 30, 2003 | 02:10 AM
Krash's Avatar
If your runner is like my truck, I'm pretty sure that the grill is the same someone correct me if i'm wrong. Anyway I did this last week, there are 4 screws holding the casing in. Get a smaller phillips and unscrew them. Do it on a surface where if the screws fall you'll be able to find them because they will fall. I was just luck enough to have extra screws I could take off of my 2wd parts truck.
Anyway you can get to them between the headlight and the chrome surround. The only problem I ran into was putting the screws back in. All I did was put the screw on the screwdriver and tape the screw to it with some scotch tape. The taping method was used after losing another screw . If I had my camera I would take some pictures tomorrow for ya.
Old Sep 30, 2003 | 04:18 AM
Churnd's Avatar
In my case, I had to remove the front grille to have access to the top and bottom screws and get the headlight out.
krimsonone
Sep 13, 2024 09:33 AM
ghostmoney
Jan 28, 2018 11:42 AM
Sep 4, 2015 09:27 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
