CEL+VSC lights on and bad lurching: Help!
Old Apr 12, 2007 | 06:38 AM
emptypockets's Avatar
I have an '02 4Runner 3.4L auto with ~74K miles. Yesterday, I was headed to a meeting with two passengers. All of a sudden, my rig started lurching badly and the CEL came on. The power came on, then went away, over and over again for about 30 seconds. As time went on, the lurching got faster and almost felt like I was driving over a set of very deep rumble strips on the road. So, I pulled over. Eventually, the CEL went out and everything seemed normal. I drove back to the office without any other issues.
Later in the evening, I was driving home and the CEL came on again, but just with a loss of power. Then both of the VSC lights came on. I have an appointment at the stealership tomorrow morning, but does anyone have any ideas on what this could be? I've checked the oil, MAF, etc, but am very curious if anyone else has had this issue. Thanks!
Old Apr 12, 2007 | 09:00 AM
Simon's Avatar
Sounds like your abs is on the fritz. Look at this write up https://www.yotatech.com/forums/show...&highlight=vsc and look at the second picture and try unplugging that connector. That plug for the abs traction control and atrac. See if the luching goes away. The ASC ATRAC and ABS lights will illuminate on the dash too. That connector could be loose too. If the luching goes away the abs unit might be bad.
-Simon
Old Apr 12, 2007 | 09:24 AM
Thanks for the input Simon. I'm thinking the VSC/ABS system might be suspect too. I've also done the AndyMod, which has worked fine. Would the ABS problem cause the vehicle to lurch like that?
Charecter1
Nov 6, 2023 10:08 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
raptor510
Feb 17, 2017 07:11 AM
fountain
Dec 31, 2015 06:08 AM
Odin
Jul 15, 2015 09:28 PM
