Catalytic Converter Captive Nuts
Old Mar 22, 2007 | 12:58 PM
mwc951's Avatar
I'm going to install a TRD exhaust on the 4Runner tomorrow.
I start PB Blasting stuff this afternoon and there is NO WAY
the intermediate pipe/cat bolts are coming out! They will
need to be cut. Once the heads are cut off I doubt the
remaining portion of the bolt is coming loose either. Has
anyone cut the captive nut off the cat and just run a bolt/nut
through??
Old Mar 22, 2007 | 06:16 PM
1994runner's Avatar
If you have access to a torch try heating them red hot and they will back out much easier. If all else fails as long as there is enough room a standard nut and bolt will work.
Old Mar 22, 2007 | 06:23 PM
YotaJunky's Avatar
... Has
through??
I have and it works just fine.
Troy
Old Mar 22, 2007 | 08:41 PM
kevin444's Avatar
through??
When i did my test pipe for the intermediate cat replacement i did the bolt and nut method.
kawazx636
Oct 6, 2021 03:03 PM
voiddweller
Oct 2, 2015 07:47 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Scotttekoch
Sep 28, 2015 10:30 PM
